Help please
So I bought a gtx 660 card, second hand from a fourm
I have it setup so one monitor is through HDMI and one is through DVI-I but with a adapter for VGA which runs my smaller monitor
I had to upgrade my PSU as it wasn't enough, so I went for a ACE 700W PSU Brand new
Whenever I run a heavy graphics game, The monitor that's on VGA develops a light pattern of lines and there is a audiable difference from the graphics card, but when I exit said game, everything turns back to normal. Meanwhile the HDMI Screen is fine.
Now is it that the graphics card is duff, or that the PSU is rubbish or the DVI-I Connector ?
I'm at a loss, thanks :)
https://linustechtips.com/topic/611253-help/
Sometimes depending on the load put on the card, the sound will change and it is completely fine.
Use the following spec style and help us spread the revolution to the rest of LTT!
"Rylo Ken"
Screenaninator: Asus Strix GTX 970
Procrastinator:Intel I7 4790K @4.0GHZ
Stickaminator: Kingston HyperX Fury (2x8)
Powermathingy: EVGA 650 GS Fully Modular
attachamajiggy: MSI Z97S SLI Krait Edition
Remembrerthing: Samsung 850 EVO 250 GB
Buttonboard: Corsair K70 RGB (browns)
Hearamagargle+talkamagargle: Logitech G35
See-A-Move-O: Logitech G502
https://linustechtips.com/topic/611253-help/#findComment-7903527
Probably a bad cable or adapter. Because vga is analog and not digital, a bad cable really can cause issues unlike digital connections like hdmi or dvi.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/611253-help/#findComment-7903532
