Should i do it?
26 members have voted
  1. 1. Should i do it?
    • Yes
      16
    • No
      10
I plan on getting 2 Ippc nf-f12 and putting them on my gpu (R9 390 Gigabyte)
any reccomendations? should i do it? please respond to the poll.
Thanks!
CPU: I5-3470
GPU: R9 390 G1 Gaming
Motherboard: Maximus IV Extreme-Z
Case: Corsair Carbide Series Spec-Alpha
PSU: EVGA Supernova 650W GS
https://linustechtips.com/topic/611154-ghetto-cooling/
4 minutes ago, Nacho Marco Segui said:
I would try it
Ok, those who voted no, please leave a comment saying why
CPU: I5-3470
https://linustechtips.com/topic/611154-ghetto-cooling/#findComment-7902526
Thanks!
People actually said no?
'ghetto' cooling is the best kind of cooling.
You can always replace the stock fans if it doesn't work out.
Make sure you post pics!
Look at my systems:
My main testing/gaming system "Bitlo" is an upgraded HP Pavilion p6710f:
AMD Athlon II X4 640 undervolted to 1.225v vcore @3.00GHz, with additional undevolts for each P-state.
Stock AMD cooler- with the undervolt that's all I actually need
8GB PNY DDR3
Zotac GTX 560 Ti, 880MHz core & 2360MHz mem at stock voltage, has been delidded and repasted, plan on strapping an AIO on to overcome current temp issues
EVGA 500W PSU
120GB Toshiba Q300 SSD
1TB Seagate HDD
Every day carry: Toshiba Satellite L655-S5150. Pentium P6200 @2.13GHz, 4GB RAM.
Black themed workstation I'm working on:
Xeon E5-2670 (SR0KX)
Cooler Master Hyper T4
ASRock X79 Extreme4
16GB (2x8) Adata XPG DDR3
Gigabyte R9 290 OC Edition
Sound Blaster Audigy 2 ZS
Dell XPS 630i 750W PSU
OCZ Vertex 3 120GB SSD
Hitachi Ultrastar 1TB HDD
Diablotek EVO ATX Midtower case
https://linustechtips.com/topic/611154-ghetto-cooling/#findComment-7902881
10 hours ago, Totalimus said:
Are you not satisfied with your current temps?
No, i am not, they get really hot and the fans are sooo loud
CPU: I5-3470
https://linustechtips.com/topic/611154-ghetto-cooling/#findComment-7905226
I will! Thanks!
CPU: I5-3470
https://linustechtips.com/topic/611154-ghetto-cooling/#findComment-7905227
What fans would you reccommend using? Are the nf-f12 ippc best for this?
CPU: I5-3470
https://linustechtips.com/topic/611154-ghetto-cooling/#findComment-7905235
They aren't a bad option- a bit expensive for my taste but certainly effective.
Which 390 is it? Is it a stock cooler or does it have the Windforce?
Generally you'd want a high static pressure fan like the NF-F12s, as you're blowing down into a heatsink and the air has to turn 90º to exit it- lots of resistance. I would suggest rigging some kind of ducting around the fans and heatsink to direct airflow the way you want it. The 390 puts out a lot of heat so assuming you started with a stock cooler you could preserve the rear-exhaust attributes with sufficient ducting.
Also, if you're comfortable with water cooling & have room in your case, the $45 you'd spend on two iPPC NF-F12s would probably be enough to buy a used 120mm AIO water cooler and RAM heatsinks instead. The Red Mod, as ziptying an AIO on an AMD GPU is known on the internet, isn't as new or novel as this, but it might be more effective.
Look at my systems:
8GB PNY DDR3
EVGA 500W PSU
1TB Seagate HDD
ASRock X79 Extreme4
https://linustechtips.com/topic/611154-ghetto-cooling/#findComment-7906542
I have a windforce gigabyte card, what do you mean by ducting?
I tried water cooling but couldnt find anything cheap for my card...
CPU: I5-3470
https://linustechtips.com/topic/611154-ghetto-cooling/#findComment-7907305
Look on ebay for 120mm all in one coolers. You don't really need a bracket for them either, you can just use zip ties. Something like the H50 or H75, or you could even go 240mm if it'll fit in your case. American ebay has a few good options in your price range with minimal searching effort.
If you have the windforce card, and the cooler still works, that explains why some people may have voted no- the windforce cooler is already very good and pretty quiet, so it might not be worth the effort.
By ducting, I meant adding material to direct the airflow around the heatsink- like the plastic shroud does on many graphics cards. It keeps air flowing across important areas instead of letting it dissipate around the edges. If you've ever seen the plastic shroud inside an original Xbox 360 you'll know what I mean.
Look at my systems:
8GB PNY DDR3
EVGA 500W PSU
1TB Seagate HDD
ASRock X79 Extreme4
https://linustechtips.com/topic/611154-ghetto-cooling/#findComment-7907354
Its really noisy and i hit 77 degrees on rocket league D; ( really low performance needed game)
CPU: I5-3470
https://linustechtips.com/topic/611154-ghetto-cooling/#findComment-7907483
Have you tried replacing the thermal paste? That might help a lot. I would see about going for a water cooled solution otherwise- if the windforce cooler isn't giving you temps you like, switching to different fans won't change the temperatures too drastically. If you aren't comfortable using zip-ties to mount an all-in-one cooler, you can always use a bracket like the NZXT Kraken or the Corsair HG10.
Look at my systems:
8GB PNY DDR3
EVGA 500W PSU
1TB Seagate HDD
ASRock X79 Extreme4
https://linustechtips.com/topic/611154-ghetto-cooling/#findComment-7907552
Its a new card, shouldnt have thermal paste problems, you mean like get a H60 and put the block on the heatsink?
No bracket supports my card.
CPU: I5-3470
https://linustechtips.com/topic/611154-ghetto-cooling/#findComment-7907666
Gigabyte 390/390Xs are garbage, so I doubt he's satisfied.
Remember to buy VRM radiators so you don't fry the power delivery system, which btw is cooled very poorly or not at all by the crappy Gigabyte cooler.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/611154-ghetto-cooling/#findComment-7907675
Whats VRM radiators? I just plan on replacing the fans...
CPU: I5-3470
https://linustechtips.com/topic/611154-ghetto-cooling/#findComment-7907678
that black thing for example: cooler3.jpg
Also, something to cool the VRAM would be nice
https://linustechtips.com/topic/611154-ghetto-cooling/#findComment-7907687
Yeah, okay, figured. You can just use zip ties. And like @Morgan MLGman said, you should definitely add heatsinks to the RAM and the VRMs to cool them if you watercool it. There's a couple great forum threads over on Overclock.net detailing the process and compiling build logs, they've been doing it for years. The Mod and The Red Mod
I hadn't known the newer Windforce cooler on the 390s was bad- the Windforce cooler on my Gigabyte R9 290 is excellent.
Look at my systems:
8GB PNY DDR3
EVGA 500W PSU
1TB Seagate HDD
ASRock X79 Extreme4
https://linustechtips.com/topic/611154-ghetto-cooling/#findComment-7907857
Do i need to do that if i just replace the fans? What about putting a CPU block on the current heatsink?
CPU: I5-3470
https://linustechtips.com/topic/611154-ghetto-cooling/#findComment-7907871
If you put a CPU AIO like the CM Seidon 120V on a GPU, you HAVE to get those heatsinks. They're cheap though.
It should look something like that, with the AIO cooler on the GPU itself: 2nun8gj.jpg
https://linustechtips.com/topic/611154-ghetto-cooling/#findComment-7907988
Thanks! Where can i get them?
CPU: I5-3470
https://linustechtips.com/topic/611154-ghetto-cooling/#findComment-7930626
Idk, ebay?
https://linustechtips.com/topic/611154-ghetto-cooling/#findComment-7930777
  • 3 weeks later...
Thanks all for all the help, I opened the card and did some measurements, I'm in the USA atm for a visit, I ordered a H80 i v2 thick to here, should drive soon.
thanks again!
CPU: I5-3470
https://linustechtips.com/topic/611154-ghetto-cooling/#findComment-8028460
