i need to be able to output my pc sound to 2 headphones. i have tried using an amplified splitter but that causes noticable distortion and negatively affects my production. is there a way to output audio to multiple headphones any other way?
if not then is there a way to stop the distortion with my current method?
https://linustechtips.com/topic/611037-output-audio-to-multiple-devices/
Have you tried using a passive splitter? If the headphones aren't too power hungry then it should work fine. The thing causing the distortion is most likely the amplification, so there's not much you can do about that. Why do you need two pairs of headphones though?
i have tried using a passive splitter but the audio is way too quiet for what i need (considering twice the headphones equals twice the power)
3 minutes ago, Motorcate said:
work stuff
If your soundcard supports stereo mix then you can do it that way
https://www.reddit.com/r/oculus/comments/2dt4dr/how_to_play_audio_through_two_devices/
if not then you need a better soundcard
You should be able to do so windows will send sound signal both to front jack and the jack on the mobo.
http://www.tomshardware.co.uk/forum/66484-63-output-audio-devices-time
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
