im just on my computer and it keeps crashing.the screen goes to one color thgat covers the hole screen.it s a diffrent color each time ie, blue red pink white. im pritty shore its my gpu iv tryed diffrent ram sticks and dusted my computer and put on  new cpu heat sink on because it was running hot. i removed the gpu and put it back into the pcie slot. any advice please ???
https://linustechtips.com/topic/610103-need-help-gpu-crashing/
If you're running a CPU with a integrated GPU, then you can try to remove your graphics card entirely and connect your monitor directly to your motherboard's I/O.
If it works absolutly fine, then you know your graphics card was the issue.
https://linustechtips.com/topic/610103-need-help-gpu-crashing/#findComment-7891053
Try to reinstall the gpu drivers.
"The Rusher" - Motherboard: Asus Z97-Pro WiFi AC CPU: Intel i7 4790K @ 4.4 GHz CPU Cooler: Coolermaster Nepton 240m RAM: Gskill TridentX 16gb 2400Mhz GPU: Gigabyte G1 Gaming GTX 1060 6GB OC Edition Storage: Samsung 850 EVO 250gb // WD Blue 1tb PSU: Silverstone Strider Gold 650w Case: Coolermaster CM 690 III Window + NZXT Blue LED's
https://linustechtips.com/topic/610103-need-help-gpu-crashing/#findComment-7891055
O okay, do you have a list of your specs?
https://linustechtips.com/topic/610103-need-help-gpu-crashing/#findComment-7891059
