Hello,
I was recently looking into mouse pad reviews and rarely do I see/read about static friction.
I've got a Corsair M45, love the mouse itself BUT what annoys me is that it takes a certain amount of force to start the movement but then it moves by much more than a pixel, so the static friction is what gives me trouble. This makes things like headshots very hard. While moving the mouse the precision is fine though.
Can any of you recommend a mouse pad that does have little static friction?
2600k, HD6870, 16GB
https://linustechtips.com/topic/610073-mousepad-without-static-friction/
well if you want as little static friction as possible you should go with a completely flat surface, such as a desk, or a piece of paper/wood
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
hard mousepad, ideally a metal surface one
edit: if I understand you correctly, you're bothered that you need more force to move the mouse from a standstill, compared to when it's already moving?
Longboarders/ skaters message me!
If you want to avoid static friction you're going to want to move to a different universe. OR fins a mouse that weighs nothing.
https://en.wikipedia.org/wiki/Friction#Static_friction
STEAM NAME: JewishBacon GPU  Sapphire dual x R9 280x OC edition CPU core i7 4770k stock speed COOLER H100i  CASE Fractal R4 Window Black  MOBO MSI gd-65 gaming Storage 1TB WD Blue drive, 1TB Samsung 7200 rpm, 120 GB OCZ SSD, 64 GB WD Blue ssd  RAM 12 GB @ 1600 Ghz kingston RAM  MiscNZXT HUE, disk read/write, 2x 21 inch 1920x1080 monitors
