Ok guys, I have tracked a problem occurring with users still running the "beta" flags as a client type.
My 780 was folding along merrily, everything looks ok for past few days - but, HFM started showing failed units. Sure enough, check the log, I have completed the WU but when I uploaded, the server is dumping the results, so I get no credit. This may explain why a lot of us seeing things looking ok, but getting no credit.
When I check the log, I can see the WU complete, the upload to the server start and then this error:
9:10:52:WU00:FS00:Server responded WORK_QUIT (404)
19:10:52:WARNING:WU00:FS00:Server did not like results, dumping
So, you get ZERO points. This has actually been happening quite a lot on my 780.
Based on these links:
http://forums.evga.com/tm.aspx?m=2030656
https://foldingforum.org/viewtopic.php?f=67&t=22529
http://hardforum.com/showthread.php?t=1782596
I checked and sure enough, I was getting this "version .47" - which is bad. These are experimental ones. So, I tried shut down, delete the WU and get a new one. Same thing, got a .47. Tried changing to "advanced" - stuck getting .47. Dammit Jim!
So, I uninstalled, making sure I SELECT the remove data check. Then reinstalled. Set flag to advanced, and voila, now using a .49 :)
We shall see how this goes.
Basically, anyone running with the BETA flag set, check and make sure you actually are getting credited. As you may not be and not even know it.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/60999-folding-with-beta-flag-issues/
You should see something like this:
19:11:54:WU00:FS00:0x17:*********************** Log Started 2013-09-29T19:11:54Z ***********************
19:11:54:WU00:FS00:0x17:Project: 8900 (Run 31, Clone 7, Gen 161)
19:11:54:WU00:FS00:0x17:Unit: 0x000000c4028c1266519a660c4ec2eaa5
19:11:54:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
19:11:54:WU00:FS00:0x17:Machine: 0
19:11:54:WU00:FS00:0x17:Reading tar file state.xml
19:11:55:WU00:FS00:0x17:Reading tar file system.xml
19:11:55:WU00:FS00:0x17:Reading tar file integrator.xml
19:11:55:WU00:FS00:0x17:Reading tar file core.xml
19:11:55:WU00:FS00:0x17:Digital signatures verified
19:11:55:WU00:FS00:0x17:Folding@home GPU core17
19:11:55:WU00:FS00:0x17:Version 0.0.49
19:13:21:WU00:FS00:0x17:Completed 0 out of 2500000 steps (0%)
19:13:21:WU00:FS00:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:16:53:WU00:FS00:0x17:Completed 25000 out of 2500000 steps (1%)
19:20:17:WU00:FS00:0x17:Completed 50000 out of 2500000 steps (2%)
19:23:51:WU00:FS00:0x17:Completed 75000 out of 2500000 steps (3%)
Notice - mine says version 0.0.49? That is good, and so is .46 - .47 is bad...
just checked and didn't find anything in that spot. the lines went from "digital signatures verified" to "completed..."
so I reinstalled with deleting all my data and now I see these two lines.
thanks for this @Whaler_99 , I've actually noticed my ppd lower than it was before so I guess this was the issue.
"I became insane, with long intervals of horrible sanity." Edgar Allan Poe
@natkoui
I didnt see that on my log, weird! Would suck if after 8h of completing a WU i got no points for it
Hey there. You are looking mighty fine today, have my virtual cookie!  :ph34r:
MY RIG: http://linustechtips.com/main/topic/34911-my-setup-gold-ghetto-gg-lots-of-pictures/#entry446883
Yep - just completed and voila - next WU worked fine.
Technically speaking... there are "beta" core 17 projects circulating, but you are supposed to need a special key to get them - by being part of the beta team. Apparently these on even have some temp sensors in the core, etc, hence the weird message on mine. As well, the version 47 was busted and it shouldn't be given out period, but some are "stuck" I guess.
