What do you mean by merge? what are you trying to accomplish here?
as far as i can tell, the first piece of code opens a error message box no matter what, and tries to open a page and play some sound then exit.
the second is run a window you defined, but is missing a return value. As far as I know, C++ requires the main function to return an int value...?
Me: Computer Engineer. Geek. Nerd.
[Educational] Computer Architecture: Computer Memory Hierarchy
[Educational] Computer Architecture:  What is SSE/AVX? (SIMD)
The error message is fake, I designed it. That's the point, I am trying to troll my friend. The second C++ is the code to run a form, I don't know how to put the code from int main() (C++ 1) into (C++2, the one with the form).
add
#include "MyForm.h"
#include<windows.h>
#include<iostream>
#include<MMSystem.h>
using namespace System;
using namespace System::Windows::Forms;
and then copy the code
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
1 minute ago, DXMember said:
add
#include "MyForm.h"
#include<windows.h>
#include<iostream>
Wait what? Add to what, I got that code in my Forms one. I need the rest of the code into my forms one but I don't know how to put the other code into that one. It's complicated to explain can I skype you or something?
are you using Visual Studio?
can I remote in with a teamviewer or something?
3 minutes ago, mattonfire said:
Hello?
I... didn't get any message
