CableMod LED Strip Help
Go to solution Solved by AHaskin14,
No PSU has a SATA port necessarily, the intention is to plug it in to the cable lined with SATA connectors that you run to your drives.
I bought 2 CableMod RGB LED strips and they use SATA power connectors but my PSU (EVGA SUPERNOVA 650W P2) doesn't have a SATA power cable port so do I have to buy an adapter or is there any other way that I can make this work?
CPU: Intel i7-6700k - GPU: EVGA GTX 1080 FTW - Motherboard: Asus Z170-A - RAM: Vengeance LPX DDR4 16GB 3000MHz - CPU Cooler: Corsair Hydro GTX H110i - PSU: EVGA SUPERNOVA 650W P2 - Case: NZXT H440 White/Black - OS: Windows 10 Home - Mouse: Logitech G502 - Keyboard: Corsair Strafe Cherry MX Red RGB
https://linustechtips.com/topic/608601-cablemod-led-strip-help/
  1. GLaDOS: i5 6600 EVGA GTX 1070 FE EVGA Z170 Stinger Cooler Master GeminS524 V2 With LTT Noctua NFF12 Corsair Vengeance LPX 2x8 GB 3200 MHz Corsair SF450 850 EVO 500 Gb CableMod Widebeam White LED 60cm 2x Asus VN248H-P, Dell 12" G502 Proteus Core Logitech G610 Orion Cherry Brown Logitech Z506 Sennheiser HD 518 MSX
  2. Lenovo Z40 i5-4200U GT 820M 6 GB RAM 840 EVO 120 GB
  3. Moto X4 G.Skill 32 GB Micro SD Spigen Case Project Fi
https://linustechtips.com/topic/608601-cablemod-led-strip-help/#findComment-7876069
