Hey guys. I am a first time water cooler. My biggest worry is getting all the fittings and such for doing all of it, so I'm gonna get a EK-KIT L360 (R2.0). It says under the notes that if I add anything to the loop I should buy a coolstream series rad. My question- if I use the 360 rad the kit comes with, could I get away with cooling a graphics card with it? (Cpu will be i7 6700k, Gpu will be a GTX 1070) Thanks guys, and have a great day!
link to the kit: https://www.ekwb.com/shop/ek-kit-l360-r2-0
https://linustechtips.com/topic/608592-ek-kit-radiator/
You can, the cooling just won't be as good.  You'll be 120mm shy of the rule of thumb(2x120mm for each component.
I've had 1 360mm and 1 240mm cooling two GPU's and a CPU and temps were fine.
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
https://linustechtips.com/topic/608592-ek-kit-radiator/#findComment-7875965
thanks man, but what do you think I should do? should I get the 240 rad and add another 240? or the 360 and add a 120? or just leave it? (sorry about this, this is my first time :D)
https://linustechtips.com/topic/608592-ek-kit-radiator/#findComment-7876180
I stay away from 120mm rads.  I try to minimize the amount of fittings and tube I use, unless it's truly beneficial.  I would get two 240's over a 360 and 120.
https://linustechtips.com/topic/608592-ek-kit-radiator/#findComment-7876526
Well I have 240mm slim rad and will be using it for i7 4790 (possible K version in future) and GTX 1070.
It might not be perfect results, but it will work.
But I can't even fit any better rad into my case, so I'm stuck with it.
If you have more space, use as big rad as you can.
But check this:
Single 240mm rad for CPU and GPU, both OCed to max and 100% load. It works and still silent.
But temps get to 70°C ... in real games probbably less, because none of the games will acctually stress your CPU and GPU to 100% like that.
So for 360mm rad ... you are fine, but for lower temps get more rads if you can.
edit: Not to mention that in this build he used some second tier brand of radiator, so with EK, you can expect better results.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/608592-ek-kit-radiator/#findComment-7877361
