Open the case and give the cooler a gentle, but firm press. If the temps go down, you didn't secure the cooler enough. It should go down pretty dramatically. If it doesn't, then something else is wrong.
https://linustechtips.com/topic/608502-help-with-cpu-temp/#findComment-7875022
try and reseat your CPU cooler and apply freash thermal paste. or it could be that the pump in your AIO liquid cooler is dying. i hate liquid cooling because there is just so much more to go wrong in liquid cooling and the price to performance ratio is not worth it
"Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning." -Albert Einstein
https://linustechtips.com/topic/608502-help-with-cpu-temp/#findComment-7875047
