19 minutes ago, Franpadi said:
So i am planing on getting a powernet, will that make a difference from plain wifi?
Also, can i just connect it directly to the wall or it has to be a router?
I have no idea what you're talking about so I'm going to guess its a wifi extender.  And they're pretty good for extending the range if you have a good network first.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/608350-wifi-questions/#findComment-7873658
