hi im going back to air cooling after many problems with water (mainly the noise) so i was looking at the noctua nh d15 but im open to recommendations
TIA Tomic
Red Fury: Cpu intel i5 4960k GPU 1060 6gb, Cooling  noctua dh15 storage 1tb sshd 250gb ssd mobo gigabyte z97p-3 case fractal r4 ram hyper x fury red 8 gb psu 550w xfx ts os win 10 monitor lg 25um56
https://linustechtips.com/topic/608287-air-cooler/
TIA Tomic
I feel like the bang for buck is CoolerMaster Hyper Evo 212. Then again, I'm not an extreme overclocker. I'd suggest watching youtube videos on the subject. There's alot of good content about which are the best ones, and common airflow configuration (case fans and cooler fans)
https://linustechtips.com/topic/608287-air-cooler/#findComment-7872892
dark rock pro 3 is nice
https://linustechtips.com/topic/608287-air-cooler/#findComment-7872928
7 minutes ago, IskanderEXC said:
not rlly, the 212 EVO is loud and bulky, with the performance being marginal CRYORIG C7 is a good option for budget and high performance
Agreed, it isn't the quietest option out there. My case/cpu fan setup is basically a hum. I don't think he's worried about bulk if he's looking at the Noctura NH-D15! There's plenty of SP fan options out there if dead silence is the objective. Just my 2c :)
https://linustechtips.com/topic/608287-air-cooler/#findComment-7872953
@Enderman do you have experience with this cooler
ive had experience with other people who have had experience with this cooler
and its a bit hard to mount but looks awesome and performs almost as well as a NH-D15
of course pretty much all tower coolers are hard to mount
https://linustechtips.com/topic/608287-air-cooler/#findComment-7872976
ok will probably go with that also its £20 cheaper than the noctua so that's good
https://linustechtips.com/topic/608287-air-cooler/#findComment-7872980
