I am in Norway and going to buy a gaming/render system. Not going to render much. Going to be a mostly white build.
Intel Core i5 6600K Overclocked
ASUS Z170-A
Crucial BallistiX Sport LT 16GB
Dual ATI HD 7970 Crossfire (I'm getting them for free from my friend)
NZXT Kraken X61
EVGA SuperNOVA 650G2
Intenso 120GB SSD
Seagate Barracuda 1TB
Fractal Design Define S
2 x Fractal Design Dynamic GP12
Windstriker 1.0
CPU: Intel Core i5 6600K
CPU Cooler: NZXT Kraken X61
Motherboard: ASUS Z170-A
Memory: Crucial BallistiX Sport LT DDR4 2400MHz 16gb (2x8GB)
GPU 1: XFX HD 7970 3GB Double Dissipation
GPU 2: Gigabyte HD 7970 3GB Windforce
SSD: HyperX Fury 120GB
HDD: Seagate Barracuda 1TB 7200RPM
Case: Fractal Design Define S
PSU: EVGA SuperNOVA 850 G2
Old Laptop
CPU: Intel Core i3 3110M
IGPU: Intel HD Graphics 4000
Memory: No-Name DDR3 4GB (1x4GB)
HDD: 443GB
https://linustechtips.com/topic/608146-build-for-me/
http://www.tomshardware.com/reviews/radeon-hd-7970-ghz-edition-review-benchmark,3232-18.html
Other than the PSU wattage, though good quality, everything looks good.
Under load the least a 7970 was 300w. Two would be 600w plus the 91w for the cpu makes it about 700w.
Everything else plus probable overclocking, I'd look into getting an 8/850w.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
https://linustechtips.com/topic/608146-build-for-me/#findComment-7871497
what about an EVGA Supernova NEX750B
Windstriker 1.0
Old Laptop
HDD: 443GB
https://linustechtips.com/topic/608146-build-for-me/#findComment-7871508
8 minutes ago, Windows10Home said:
get a 6700 (non k). it costs the same because you can get a cheaper cooler and motherboard. also it performs the same as OC'd 6600k in games and is way better for rendering.
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
https://linustechtips.com/topic/608146-build-for-me/#findComment-7871524
I can see why you'd want that one because it's cheap but there is a reason why it is cheap.
The EVGA B series is not the highest rated in terms of quality and I still feel like it would limit you.
Your power supply touches everything in the computer so I wouldn't cheap out on it.
https://linustechtips.com/topic/608146-build-for-me/#findComment-7871558
I am buying from here. The site is sorted by price
Windstriker 1.0
Old Laptop
HDD: 443GB
https://linustechtips.com/topic/608146-build-for-me/#findComment-7871574
How about a Supernova 750G2
Windstriker 1.0
Old Laptop
HDD: 443GB
https://linustechtips.com/topic/608146-build-for-me/#findComment-7871582
I would recommend the 850g2 but I do see a price difference of +200.
I don't know if that's too much. The g2 is an extremely high rated PSU.
You'll probably be pretty close to max power draw with little headroom but a 750w might just cut it.
https://linustechtips.com/topic/608146-build-for-me/#findComment-7871597
I can use all of my budget getting a 850W, but I wanted to save some money
Windstriker 1.0
Old Laptop
HDD: 443GB
https://linustechtips.com/topic/608146-build-for-me/#findComment-7871612
You might want to look into seeing if this is true. If you can come out better getting the i7 non-k, it might suit you better as it'll have less power draw since you wont be able to touch the clock and voltages.
https://linustechtips.com/topic/608146-build-for-me/#findComment-7871647
