https://linustechtips.com/topic/607894-will-these-work-together/
4 minutes ago, kingpenguin said:
What is his budget? These will work, it's not well balanced though.
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/607894-will-these-work-together/#findComment-7868932
Please don't get a CX PSU.
But yes, just glancing at it, those parts should work.
Stick it on PC part picker to be sure
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/607894-will-these-work-together/#findComment-7868936
5 minutes ago, kingpenguin said:
pcpartpicker.com is your friend...
https://linustechtips.com/topic/607894-will-these-work-together/#findComment-7868937
These parts are completely compatible, but a few things to keep in mind.
Z97 is a board that supports overclocking. i5-4590 is a chip that does not support overclocking. Find a chip with a K at the end of its name, such as 4770k in order to overclock, OR consider getting a different board.
As far as not wanting to waste money, a lot of these parts are outdated or belong to previous generations. You can likely get better performance out of a similarly priced system, or much better performance if you're willing to pay a slight amount more if you get more recent stuff (especially your GPU).
However, if you're dead set on getting these items, they ARE 100% compatible with each other.
https://linustechtips.com/topic/607894-will-these-work-together/#findComment-7868950
This parts do work with each other indeed, however I don't think money is spent wisely.
The GPU is the part where you want to spend most of the budget, Get an i5 6500 + cheap H110 motherboard. and get at least a R9 380 GPU.
TBH it's best to wait a little for the GPU, new releases are coming very soon.
https://linustechtips.com/topic/607894-will-these-work-together/#findComment-7868955
1 minute ago, kingpenguin said:
The budget that my friend is looking at is $1000 tops but would like to go cheaper
Does said friend want to overclock?
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/607894-will-these-work-together/#findComment-7868957
No just wants a pc that can run games at a good fps isn't really into computer right now but that might chabge down the road
Can he wait for the RX 480 to come out?
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/607894-will-these-work-together/#findComment-7868971
15 minutes ago, kingpenguin said:
So what i'm seeing is look into better GPU's such as the R9 380, a better power supply, and a CPU that can overclock?
https://linustechtips.com/topic/607894-will-these-work-together/#findComment-7869005
Keep in mind that 4xxx CPUs are from the previous gen, they still kick ass, but you might want to look into the new (latest) generation, which is Skylake. It supports DDR4 as well as a couple minor new features, including a bit better performance and less power consumption. This is the reason I suggested the i5 6500 and the H110 motherboard (which are socket 1151).
At the end of June we should see the RX 480 appear on the shelves. It should deliver much more performance in theory. (for $199).
https://linustechtips.com/topic/607894-will-these-work-together/#findComment-7869134
