Looking for a monitor to compliment my first PC build. From other forum posts, I've gathered that given my graphics card, Sapphire Radeon R9 390, it would be very beneficial to buy a monitor with FreeSync capabilities to avoid choppy gameplay or broken frames. I'm looking to spend around $150 for it but will go to a max of $200. Based on videos I've watched, IPS panel monitors have better angle viewing and colors which can enhance gameplay. I have been unable to find a monitor with FreeSync and an IPS panel that fits into my budget. Are there any monitors like this out there? If not, is IPS really a necessity or will a TN panel be okay for 1080p gaming? Also I'd like to be able to hook up my monitor to my laptop occasionally or to other devices via HDMI so having both an HDMI port and a display port would be great. Briefly searching online I found some adapters that might help me work around this if the monitor only has a display port. Thanks in advance for any help anyone can give me.
https://linustechtips.com/topic/607519-need-help-with-monitors/
http://pcpartpicker.com/product/DCL7YJ/samsung-monitor-s24e370dl
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/607519-need-help-with-monitors/#findComment-7865032
10 minutes ago, Jvill40 said:
You'll want to wait for this LG one then
LG 23MP68VQ-P | LG Electronics UK
It's 1080p IPS 75Hz with free-sync over HDMI
but it's only in the UK for now, should be like $130 ish
did you already buy the 390? because the RX 480 will be out shortly and is a better choice overall
1080p 144hz TN display, it really isn't too bad given that you get 144hz with it, this one is $209 on sale atm
https://pcpartpicker.com/product/ZBZ2FT/aoc-monitor-g2460pf
https://linustechtips.com/topic/607519-need-help-with-monitors/#findComment-7865052
Forgot to mention that I did find that Samsung monitor in my recent search. Unfortunately I have an iPhone and wouldnt be able to use that feature. If this is the only monitor that can meet all my criteria then I guess I can go with this one and just ignore the charger. Thanks for the quick response though.
https://linustechtips.com/topic/607519-need-help-with-monitors/#findComment-7865054
That samsung display is pretty overpriced I'd say, given that you can get 1080p 60Hz IPS displays for around $100
this one even has VESA compatibility
http://pcpartpicker.com/product/kKYXsY/aoc-monitor-i2269vw
https://linustechtips.com/topic/607519-need-help-with-monitors/#findComment-7865061
