Ok guys at the moment i am using 19inch [1280x1024] monitor and my distance from it is 70cm +/- 5cm.
I plan buying 1080p [24inch] monitor or 1440p [27inch] what will be the save distance to look at them, so i dont have any headaches or get my eyes fucked. [Healty distance]
Btw i am using Flux software tho.
Thank you in advance!
- Redjo
Project Redline:
♦CPU: i7-5820k  ♦CPU Cooler: Kraken x61 ♦Mobo: MSI X99A SLI ♦RAM: G.Skill Ripjaws 4x4GB 3200mhz ♦GPU: Evga 980Ti Hybrid ♦Case: NZXT H440 ♦SSD: Samsung 850EVO 500GB ♦HDD: WD BLUE 1TB 7200rpm ♦Display: 1280 x 1024
https://linustechtips.com/topic/606827-19inch-and-27inch/
And don't know anything about healthy distance, I think you should look serious sources just to see if it exists, but anyway, 70 cm seems to be a nice distance to be from you monitor. At that distance, both should be fine, although the 1440p should be sharper in terms of details.
https://linustechtips.com/topic/606827-19inch-and-27inch/#findComment-7867522
