Hello, I have just finished building my Pc today and currently have a bootable USB 3.0 stick. However when i get toe installation screen I get stuck after language because I am told that "there are no device drivers found" can someone please help. I have used the installer creator to update the 3.0 drivers however I am still getting the same message any help would be greatly appreciated. Thanks.
- Encoded
https://linustechtips.com/topic/606298-bootable-usb-help/
Try using a CD instead as some mobos have trouble booting some OS's off USB
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
https://linustechtips.com/topic/606298-bootable-usb-help/#findComment-7852806
Elemental
Laptops
https://linustechtips.com/topic/606298-bootable-usb-help/#findComment-7852824
