Logitech G810 help
Go to solution Solved by Frode,
when i was searching for a keyboard, i tried the romer-G switch but on the g910 keyboard the first keyboard with the romer-G. I personally like the fell off the romer-G, were you really can feel the actuation point off the switch. The romer-G switch also has the leds positioned in the center off the keyswitch intead fo on top which helps with not so much backlit bleed, which is good. But because i don`t own the g810 i can`t really comment on the wrist wrest, but i have tested other keyboards with this kind off layout like the quickfire tk from cm. I can`t really type on the a keyboard without a proper wrist wrest, which is why i went with the k70 rgb. I feel like it is a shame that logitech did not include a wrist wrest, but i also don`t want them to include one because off the failure with the g910`s wrist wrest which was really horrible. But some people rest thier hands on the table instead off the wrist wrest.
But it is down to personal preference. I think that you should go for it due to the price cut and that the division is included.
So i want to buy a Logitech G810 Orion Spectrum because i found it at a local dealer at half the price + the division for free but im a little bit concerned about the Romer-G switches and the comfort since it has no wrist rest, if anyone could help me decide, tell me about the switches and the comfort, thanks !
https://linustechtips.com/topic/605812-logitech-g810-help/
https://linustechtips.com/topic/605812-logitech-g810-help/#findComment-7848355
