Posted June 3, 2016 Which one is better for gaming? Intel Core i7 4790 CPU - Stock cooler - Gigabyte GTX 1080 GPU Asrock Z97 Pro4 Motherboard - HyperX 16GB DDR3 1866 MHz Ram (Dual Channel) - Cooler Master V750 PSU Samsumg Evo 250gb SSD - Segate 2TB - NZXT S340 Mid-tower. Link to comment https://linustechtips.com/topic/605756-frame-rate-vs-resolution/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 3, 2016 2 minutes ago, Rhett Quigley said: Which one is better for gaming? 144Hz. Only on 4K people say image is so smooth even drops under 60 are not noticable as much. Connection: 200mbps / 12mbps 5Ghz wifi My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE Link to comment https://linustechtips.com/topic/605756-frame-rate-vs-resolution/#findComment-7847567 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 3, 2016 Im more for the immersion smooth 60fps 1440p IPS experience Let's agree to disagree Link to comment https://linustechtips.com/topic/605756-frame-rate-vs-resolution/#findComment-7847578 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 3, 2016 Personally, unless we're talking 27"+ monitors, I'd just go for 1080p 144hz. Check out my guide on how to scan cover art here! Local asshole and 6th generation console enthusiast. Link to comment https://linustechtips.com/topic/605756-frame-rate-vs-resolution/#findComment-7847591 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 3, 2016 1080p at 144hz is better for FPS gaming. Link to comment https://linustechtips.com/topic/605756-frame-rate-vs-resolution/#findComment-7847628 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 3, 2016 27"+ = 1440p. Under 27" I'd say 1080p. But then, make sure the system in question can even play games at 1440p or 1080@144hz. If you cannot, may be better off spending the money on better hardware before a new monitor. D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200 Link to comment https://linustechtips.com/topic/605756-frame-rate-vs-resolution/#findComment-7847643 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 3, 2016 i think everybody's comfortable "unnoticeable" frame rate varies from person to person. 60's a turd sometimes, sometimes it's not. then there are people who say it is okay just to feel at ease with the expensive monitor they purchased. me, I like the 90+ end of things. then of course you need to take the game in question under consideration. FPS and racing games I find respond better to higher refresh rates making them more enjoyable to play. then you need to consider the size of the monitor vs the resolution of that monitor. Link to comment https://linustechtips.com/topic/605756-frame-rate-vs-resolution/#findComment-7847757 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 3, 2016 To me, much of this depends on the games being played. If you are playing competitive FPS then 1080 144. If you are more of a RPG player, I would definitely go with the 1440. Link to comment https://linustechtips.com/topic/605756-frame-rate-vs-resolution/#findComment-7847759 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 3, 2016 1 hour ago, Dingus said: To me, much of this depends on the games being played. If you are playing competitive FPS then 1080 144. If you are more of a RPG player, I would definitely go with the 1440. Exactly, there is no "better for gaming", there are different games, styles and needs. @Rhett Quigley You need to define what games you want to play. For FPS/competitive gaming, 144Hz is better, but for RPG and alike, 1440p or 29" 2560x1080 ultrawide. You have R9 390, so some 29" 2560x1080 75 Hz FreeSync ultrawide from LG would fit your system perfectly. Also you didn't say anything about budget. Spoiler CPU: i7-6900K 4.5 GHz | Motherboard: X99 Sabertooth | GPU: RTX 2080 Ti SLi | RAM: 32GB DDR4-3400 CL13 | SSD: SX8200 PRO 512GB | PSU: Corsair AX1600i | Case: InWin 805C | Monitor: LG 38UC99-W 85Hz | Keyboard: Wooting One Analog | Keypad: Azeron Compact Analog | Mouse: Swiftpoint Z | Audio: Klipsch Reference 5.1 Link to comment https://linustechtips.com/topic/605756-frame-rate-vs-resolution/#findComment-7848123 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 3, 2016 Author 4 minutes ago, Krzych said: Exactly, there is no "better for gaming", there are different games, styles and needs. @Rhett Quigley You need to define what games you want to play. For FPS/competitive gaming, 144Hz is better, but for RPG and alike, 1440p or 29" 2560x1080 ultrawide. You have R9 390, so some 29" 2560x1080 75 Hz FreeSync ultrawide from LG would fit your system perfectly. Also you didn't say anything about budget. I pretty much only play fps games online. I already have a 25" 1440p monitor, which I can tell is an improvement over 1080p, but not drastic. People say that a 144hz over 60hz is a drastic difference, and I can picture it being a huge advantage in competive games I play. Intel Core i7 4790 CPU - Stock cooler - Gigabyte GTX 1080 GPU Asrock Z97 Pro4 Motherboard - HyperX 16GB DDR3 1866 MHz Ram (Dual Channel) - Cooler Master V750 PSU Samsumg Evo 250gb SSD - Segate 2TB - NZXT S340 Mid-tower. Link to comment https://linustechtips.com/topic/605756-frame-rate-vs-resolution/#findComment-7848157 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 3, 2016 27 minutes ago, Rhett Quigley said: I pretty much only play fps games online. I already have a 25" 1440p monitor, which I can tell is an improvement over 1080p, but not drastic. People say that a 144hz over 60hz is a drastic difference, and I can picture it being a huge advantage in competive games I play. There is a big difference in games in which you can make use of this 144Hz and run game at very high framerates, and game itself has to be of characteristic where you can benefit from higher refresh rate, it has to be very dynamic. But many games cannot be run nowhere near 100FPS+ withou crazy multi GPU setups, and are not super dynamic, so overall difference between 60/75 and 144Hz is not that drastic across all games. But in very dynamic FPS games with low requirements like CS:GO it definitely makes difference. So if you play only this kind of games, then get 1080p 144Hz. Problem is that 144Hz 1080p IPS monitors doesn't exist, so you would have to get monitor with low-end panel. Spoiler CPU: i7-6900K 4.5 GHz | Motherboard: X99 Sabertooth | GPU: RTX 2080 Ti SLi | RAM: 32GB DDR4-3400 CL13 | SSD: SX8200 PRO 512GB | PSU: Corsair AX1600i | Case: InWin 805C | Monitor: LG 38UC99-W 85Hz | Keyboard: Wooting One Analog | Keypad: Azeron Compact Analog | Mouse: Swiftpoint Z | Audio: Klipsch Reference 5.1 Link to comment https://linustechtips.com/topic/605756-frame-rate-vs-resolution/#findComment-7848266 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 3, 2016 Author 7 minutes ago, Krzych said: There is a big difference in games in which you can make use of this 144Hz and run game at very high framerates, and game itself has to be of characteristic where you can benefit from higher refresh rate, it has to be very dynamic. But many games cannot be run nowhere near 100FPS+ withou crazy multi GPU setups, and are not super dynamic, so overall difference between 60/75 and 144Hz is not that drastic across all games. But in very dynamic FPS games with low requirements like CS:GO it definitely makes difference. So if you play only this kind of games, then get 1080p 144Hz. Problem is that 144Hz 1080p IPS monitors doesn't exist, so you would have to get monitor with low-end panel. Yeah, its either smoothness or high quality monitor. Intel Core i7 4790 CPU - Stock cooler - Gigabyte GTX 1080 GPU Asrock Z97 Pro4 Motherboard - HyperX 16GB DDR3 1866 MHz Ram (Dual Channel) - Cooler Master V750 PSU Samsumg Evo 250gb SSD - Segate 2TB - NZXT S340 Mid-tower. Link to comment https://linustechtips.com/topic/605756-frame-rate-vs-resolution/#findComment-7848294 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 3, 2016 16 minutes ago, Rhett Quigley said: Yeah, its either smoothness or high quality monitor. It should change with time, resfresh rate will grow with technology and more manufacturers should decide and be able to create all in one monitors, with both quality high refresh rate. So far there is only some gaming garbage from joke manufacturers like Asus or Acer, IPS 144Hz+ with terrible quality issues and terrible price, but it will change with time, more manufacturers will create high refresh rate monitors and push their quality panels and products to higher refresh rate. I am okay with 60 and 75 Hz, so no problem for me, I just want OLED for perfect image quality. Spoiler CPU: i7-6900K 4.5 GHz | Motherboard: X99 Sabertooth | GPU: RTX 2080 Ti SLi | RAM: 32GB DDR4-3400 CL13 | SSD: SX8200 PRO 512GB | PSU: Corsair AX1600i | Case: InWin 805C | Monitor: LG 38UC99-W 85Hz | Keyboard: Wooting One Analog | Keypad: Azeron Compact Analog | Mouse: Swiftpoint Z | Audio: Klipsch Reference 5.1 Link to comment https://linustechtips.com/topic/605756-frame-rate-vs-resolution/#findComment-7848350 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 3, 2016 Author 25 minutes ago, Krzych said: It should change with time, resfresh rate will grow with technology and more manufacturers should decide and be able to create all in one monitors, with both quality high refresh rate. So far there is only some gaming garbage from joke manufacturers like Asus or Acer, IPS 144Hz+ with terrible quality issues and terrible price, but it will change with time, more manufacturers will create high refresh rate monitors and push their quality panels and products to higher refresh rate. I am okay with 60 and 75 Hz, so no problem for me, I just want OLED for perfect image quality. The cheapest 144hz monitor I have seen is $190. http://www.amazon.com/Acer-GN246HL-Bbid-24-Inch-Display/dp/B00KO4518I/ref=sr_1_1?s=pc&ie=UTF8&qid=1464988559&sr=1-1&keywords=144hz+monitor Intel Core i7 4790 CPU - Stock cooler - Gigabyte GTX 1080 GPU Asrock Z97 Pro4 Motherboard - HyperX 16GB DDR3 1866 MHz Ram (Dual Channel) - Cooler Master V750 PSU Samsumg Evo 250gb SSD - Segate 2TB - NZXT S340 Mid-tower. Link to comment https://linustechtips.com/topic/605756-frame-rate-vs-resolution/#findComment-7848487 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 3, 2016 10 minutes ago, Rhett Quigley said: The cheapest 144hz monitor I have seen is $190. http://www.amazon.com/Acer-GN246HL-Bbid-24-Inch-Display/dp/B00KO4518I/ref=sr_1_1?s=pc&ie=UTF8&qid=1464988559&sr=1-1&keywords=144hz+monitor Get FreeSync one for your 390. Spoiler CPU: i7-6900K 4.5 GHz | Motherboard: X99 Sabertooth | GPU: RTX 2080 Ti SLi | RAM: 32GB DDR4-3400 CL13 | SSD: SX8200 PRO 512GB | PSU: Corsair AX1600i | Case: InWin 805C | Monitor: LG 38UC99-W 85Hz | Keyboard: Wooting One Analog | Keypad: Azeron Compact Analog | Mouse: Swiftpoint Z | Audio: Klipsch Reference 5.1 Link to comment https://linustechtips.com/topic/605756-frame-rate-vs-resolution/#findComment-7848539 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 3, 2016 Author 1 minute ago, Krzych said: Get FreeSync one for your 390. Yeah, its $20 more lol. Intel Core i7 4790 CPU - Stock cooler - Gigabyte GTX 1080 GPU Asrock Z97 Pro4 Motherboard - HyperX 16GB DDR3 1866 MHz Ram (Dual Channel) - Cooler Master V750 PSU Samsumg Evo 250gb SSD - Segate 2TB - NZXT S340 Mid-tower. Link to comment https://linustechtips.com/topic/605756-frame-rate-vs-resolution/#findComment-7848541 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
