CPU upgrade advice
Well the B150 is a business class chipset and the H170 is a consumer class chipset. largely speaking these would be quite similar. the H170 would come with better/more USB 3.0 support, native Raid capabilities, more PCIE lanes and the like. the B150 whilst aimed at being a business class chipset, since its so cheap and shares many similar features to the H170, it has also been remodeled by some companies as a "gaming" chipset. For the purposes of gaming, the H170 is definitely the better choice, but in alot of cases it will be more expensive (but not by much) for the features you get. people who (typically) use the B150 set are making low end budget gaming builds, but if you're making a medium to high end gaming build, the H170 would be the way to go.
But the big thing at the end of the day is price, and whatever is within your budget is what you should get. I would recommend the H170 over the B150 because it has features that I consider useful (such as native RAID). However if you think the H170 has a bunch of unnecessary fluff that you wont use in comparison to the B150, then there is no reason for you to spend the little bit of extra cash to get a H170.
Here is a link to a quick and dirty rundown of the two chipsets (and actually all 6 skylake chipsets). Whilst your individual motherboards will put their own bells and whistles onto these chipsets, this should give you at least a starting point of what to look for. another thing to keep in mind is some features will differ from board to board. A high end B150 board MIGHT have more usb ports or m.2 or things like that than a mid-low end h170 board (IF the manufacturer decides to make a board like that)
If you're looking for a simple "what do I buy", I would personally recommend the H170 (but again, that's because there are features on it I would use and I deem valuable). However, as you said your budget is tight, and there is NOTHING wrong with a B150 board if it has everything you think you need.
On www.newegg.ca Your suggested Gigabyte G1.Snuper B7 B150 board costs 139.99 CAD (Canadian Rupees)
A similarly priced H170 gigabyte board like the Gigabyte G1 Gaming 3 H170 board is 129.99 CAD (Canadian Rupees)
In this comparison, the H170 G1 gaming matches every feature the B150 has or surpasses it. This H170 board is directly better in every way (unless you're really into green and black aesthetics) and its 10$ cheaper (at least in Canada, your mileage may vary on that one)
TL:DR
I would HIGHLY recommend getting this motherboard if you can afford it. There are certainly some cheaper options if you're really strapped for cash, but this quite inexpensive as motherboards go, and has everything you could possibly need. There is also nothing wrong with your choice of the B150 Sniper board you mentioned, looks like a fine board (although the one I linked is better and cheaper, at least in Canada at the moment).
http://pcpartpicker.com/product/wBZ2FT/gigabyte-motherboard-gah170gaming3
If you need something cheaper, let me know and I'll do further research into some REALLY cheap skylake boards and see what gold nuggets I can find.
