Yesterday after playing like 4-5h of Total War Shogun 2 I saw on Asus Tweak II that: http://imgur.com/a/ztMdJ.
(On reddit) I posted a post yesterday but everyone was asleep so didn't get a lot of answer. But someone told me to Download GPU Z to double check and maybe it was just a program problem.
After DLing GPU Z (http://gpuz.techpowerup.com/16/06/03/c36.png)
Still the same.
I am kinda worry, a lot. But I recently updated my GPU drivers from GeForce Experience. Might have to do with that ?
Spec:
CPU: i7 5820k 3.3G
GPU GTX 970 Strix ASUS
MB: Asus X99-A
RAM: Kingston DDR4 2300 2X8GB
Edit: It's during Idle not on gaming or load.
Edit: My temp keep going up, normally during summer it goes up to 47C on Idle but now doing nothing it stay at 50-56C
Edit: Now going  up to 60C, WTF. I am doing nothing.
https://linustechtips.com/topic/605590-gpu-problems/
Okay, go to Control Panel and uninstall all your GeForce drivers. That means the display driver, the physx driver, everything. Restart your PC.
Then go to Nvidia.com and download their latest installer for your OS and GPU.
Run that installer, and do not select Express settings, use custom settings and select the option that deletes everything previous and installs everything clean. Restart your PC again and run whatever test you were running that showed the problems.
https://linustechtips.com/topic/605590-gpu-problems/#findComment-7845725
4 minutes ago, thearthurusrex said:
Well don't know what a Clean install is but took like 2-3 mins and everything was fine, no blue screen or black screen or anything. Downloaded and installed, ready to go.
A clean install is a completely new install of something, Dogeystyle is asking weather you upgraded the driver or installed it before there were drivers for that graphics card installed. If that makes sense.
[insert] Cool signature [/insert]
///Nailed It
https://linustechtips.com/topic/605590-gpu-problems/#findComment-7845734
I am kinda new to PC and I don't want to fuck it up. Is it hard or anything ?
https://linustechtips.com/topic/605590-gpu-problems/#findComment-7845735
Make a lot of sense, Did upgrad not clean install.
https://linustechtips.com/topic/605590-gpu-problems/#findComment-7845738
Nah, it won't break anything. Everyone who's ever owned a PC has had to do a clean driver install at least once in their life.
https://linustechtips.com/topic/605590-gpu-problems/#findComment-7845739
The  physx driver is in the GPU driver right ? (saw it goes by the installation of the new driver.)
https://linustechtips.com/topic/605590-gpu-problems/#findComment-7845750
That approach won't work actually. In order to properly remove GPU drivers you must use DDU (Display Driver Uninstaller) and then install 361.75 - all the newer drivers are piss poor and broken
No they are not.
https://linustechtips.com/topic/605590-gpu-problems/#findComment-7845751
The PhysX driver is separate from the display driver, since you can have a display driver without a PhysX driver. But the PhysX driver cannot work without a display graphics driver.
https://linustechtips.com/topic/605590-gpu-problems/#findComment-7845757
No they are not.
How I get the Phys X driver then ? That's what I heard about new Drivers they aren't that good some time.
https://linustechtips.com/topic/605590-gpu-problems/#findComment-7845767
You can't. The recent driver issues are not related to PhysX - the whole drivers are from bad to worse. Download DDU, run in safe mode, uninstall EVERYTHING then download 361.75 full package and you're golden
https://linustechtips.com/topic/605590-gpu-problems/#findComment-7845771
The Nvidia installer will ask you if you want to install their display driver, physx driver, along with the audio driver and the 3D driver(useless) when you select the Custom Installation option when you run the installer.
https://linustechtips.com/topic/605590-gpu-problems/#findComment-7845774
Manually uninstall them from drivers panel isnt better ? I don't know DDU.
https://linustechtips.com/topic/605590-gpu-problems/#findComment-7845782
Uninstalling from Control Panel won't fix anything - the driver installer leaves a LOT of files behind when it finishes the install and those files interfere with future installations. DDU is the ONLY way I recommend removing them which is guarantee to work properly
https://linustechtips.com/topic/605590-gpu-problems/#findComment-7845790
Where I download it ? a safe place.
https://linustechtips.com/topic/605590-gpu-problems/#findComment-7845806
http://www.guru3d.com/files-details/display-driver-uninstaller-download.html
https://linustechtips.com/topic/605590-gpu-problems/#findComment-7845812
My anti virus is freaking out ?
Your AV is braindead. Have been using this for years personally and on every PC I've built - never had an issue.
If you are using AVG/McAfee/Avast I strongly suggest you do a reinstall of windows/remove them. AVG is a Virus in it of itself and should be treated as such
https://linustechtips.com/topic/605590-gpu-problems/#findComment-7845830
Using Emisoft.
https://linustechtips.com/topic/605590-gpu-problems/#findComment-7845838
Using Emisoft.
Never heard of it. You might want to move over to something like MalwareBytes or Symantec.
https://linustechtips.com/topic/605590-gpu-problems/#findComment-7845841
After installing the driver, things are the same. my temp goes up and GPU Z say the same (info and monitor)
This is at idle?
https://linustechtips.com/topic/605590-gpu-problems/#findComment-7845909
