Heat/Booting issues
Go to solution Solved by m157,
I do have the stock cpu cooler unused in a box i can go grab, I can order some thermal paste quickly, ill try going to stock for a bit
What can i use to clean the cpu/block?
I have a FX 8350 with a Asus M5A97 LE R2.0 mobo, with a Corsair H100i cooler
The computer will get to the very start of windows then shut down, VRM is cool, If i feel under the H100i where the cpu is, its hot as hell
Its been working fine for 3 years now, just started acting up with heat issues...
Anyone got any ideas
https://linustechtips.com/topic/605309-heatbooting-issues/
Can you see the temps in windows? Or does it turn off to quickly?
Can you get into the BIOS? You should be able to see the temps there.
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/605309-heatbooting-issues/#findComment-7842798
Could the pump have died? Or the fan? Or the PSU?
https://linustechtips.com/topic/605309-heatbooting-issues/#findComment-7842812
If it worked before I would first check the pump (can you hear it?), fans (rpm) and the radiator (dust or leaks). Check for proper seating of the CPU block and replace the thermal paste in case you haven't changed it in the last 3 years.
https://linustechtips.com/topic/605309-heatbooting-issues/#findComment-7842832
The pump maybe, all fans work fine, psu seems fine
Just got into bios for 10 seconds, cpu was 44c, mobo was lower
It might be the pump...
https://linustechtips.com/topic/605309-heatbooting-issues/#findComment-7842842
Can you hear the pump working?
44 C is a bit warm but it's not terrible. Does the temp increase overtime?
https://linustechtips.com/topic/605309-heatbooting-issues/#findComment-7842890
I turn on, get into bios, and less then 5 seconds later, shuts downs, Does the pump make any noticeable motion?
Forgot to put, bios says ~2280 rpm for cpu fan (the pump_
https://linustechtips.com/topic/605309-heatbooting-issues/#findComment-7842897
No, the pump itself is in the CPU block on most all in one liquid coolers. But you might hear it / feel the block vibrating if it's working at all.
It might be temperature related since it's quickly shutting down. So the pump could be to blame.
https://linustechtips.com/topic/605309-heatbooting-issues/#findComment-7842910
