Up/Down Speed help
By
zBxrbxri
in Networking
in Networking
Solved by Lurick,
Sounds like the WiFi card is just plain crap, if you have a long enough cable to test I would try plugging up directly and doing the test. Just remember, speedtest shows output in MegaBITs while steam download shows in MegaBYTEs. 1 MB = 8Mb, so on a 50/50 connection you should see roughly 6MBps on steam downloads.
5
kasdashd ·
2
6
Ishikudeska ·
Posted in New Builds and Planning2 -
Xxu ·
Posted in Servers, NAS, and Home Lab1
play_circle_filled
Latest From ShortCircuit:
