Hey guys, I recently bought a biostar ta970 v5.3 and im having some issues. When I install all the components into the board and double check to make sure everything is seated correctly, and I turn the power on. the CPU fans come on, hard drives come on, video card fan spins but I get no video signal. I called biostar and they said it could be my power supply. Been trying to search around the internet for a answer. Does anyone have any idea what could be the issue? I double checked on there website and my cpu is supported by the board so also isn't a issue.
https://linustechtips.com/topic/604904-ta970-issues/
dead GPU?
Broken cable?
Monitor not functioning properly?
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/604904-ta970-issues/#findComment-7838221
GPU is working, as it draws power from the board. I have a separate board that im upgrading from and it works fine on that board. I have two different video cards, one of them when I put it in, the fan doesn't even spin up but does on the other board and works fine.
https://linustechtips.com/topic/604904-ta970-issues/#findComment-7838234
First thing: make sure the problem is within the PC. I, for one, have a dead HDMI input on one of my monitors; I've also had a dead cable in the past as well. Likewise, try a different video output - guess what, I have a defective (though not dead) HDMI exit on one of my cards as well.
Outside of that, does your mobo make any beep? That could help diagnose the problem.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/604904-ta970-issues/#findComment-7838238
Currently my internal speaker is dead. I need to buy a new one so I can't get any beeps or anything from it. So ya thats making things a lot harder on me.
https://linustechtips.com/topic/604904-ta970-issues/#findComment-7838248
so i bought a new internal speaker, began to hook everything up. it started to post and such. i get it all hooked up and in the case, it was staying on for a good 20 mins, then everything just went poof. turned off but without shutting down. cpu cooler fan still spinning along with psu fans spinning. now it wont post at all
https://linustechtips.com/topic/604904-ta970-issues/#findComment-7849355
