Hello, I need help with compatibility between the PC parts I picked, I suspect the MoBo isn't compatible with the GPU and RAM and I need case references. I want the MoBo to be a cheap or mid range in pricing and ATX size.
Here's my build currently : http://pcpartpicker.com/list/6p448K
My budget is probably 700+ or lower but at this point Ill roll with 750 or higher since my job in 8 weeks is going to give me $1k but preferably I dont want to go over $1k and my goal is to have a decent gaming rig that can run all games, preferably Blade and Soul, Tera, Vindictus, Payday 2, and XCOM 2
https://linustechtips.com/topic/604757-my-first-gaming-pc-build-help/
Budget? Goal?
38 minutes ago, Zeinone said:
Just don't get the 960, wait for the RX 480 (end of june), other than that looks fine. You could only try getting a higher quality psu.
Yeah pretty much this.
a Moo Floof connoisseur and curator.
:x@handymanshandle x @pinksnowbirdie || Jake x Brendan :x
Youtube Audio Normalization
Why? whats so good about that? I like Nvidia stuff more than AMD but I'm willing to make that buy
Don't be a fanboy. I firstly wanted to get a 970 but switched to 390 because its better for that price (even cheaper). Wait until some benchmarks get out for the RX 480, even the 380 is better than the 960 and it's around that price
