Hi, right now I am using the OG Earpods, the sound is nice, but the cable is a little bit annoying while running. I would like to use them at the gym, but I can't do exercise with the phone on my arm and the cable moving around.
https://www.amazon.es/Auriculares-Bluetooth-Deportivos-Autonom%C3%ADa-Compatible/dp/B017M3CMQM/ref=sr_1_13?ie=UTF8&qid=1464794075&sr=8-13&keywords=mpow
I don't know if these are good, hope you guys can tell or even suggest a better option.
https://linustechtips.com/topic/604609-looking-for-running-bluetooth-earbuds/
