[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
https://linustechtips.com/topic/604599-fans/#findComment-7834717
21 minutes ago, DaGallane said:
Does this build have enough air distribution in it, or will I need more fans? Thanks.
http://pcpartpicker.com/list/bYRypb
Am I not seeing a GPU?
Project "Transcend": i7 7700k-R9 380 4GB by MSi, Z170-HD3P
My Steam Profile (from SteamDB)
  • Worth: $453 ($123 with sales)
  • Games owned: 76
  • Games not played: 40 (53%)
  • Hours on record: 667.0h
https://linustechtips.com/topic/604599-fans/#findComment-7834812
Unless your case has special needs, two intakes and one exhaust is a good rule of thumb. I try to ensure that I have more air coming in than going out to keep positive pressure and force dust out.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/604599-fans/#findComment-7835357
So do I need to purchase a separate fan or is there already 3 included? Thanks.
https://linustechtips.com/topic/604599-fans/#findComment-7837636
Fractal's site says it comes with two GP-14 fans. You could pick up one more fan if you wanted to, or just roll with the included fans to start out and see if you need another intake at all.
https://linustechtips.com/topic/604599-fans/#findComment-7837791
Apologies on asking so many questions, but is there an indicator that dictates whether or not I will need a new fan? Will certain parts overheat quicker than others,so I need to monitor those parts? Thanks.
https://linustechtips.com/topic/604599-fans/#findComment-7837802
The odds of anything overheating in your system are pretty low. I use HWMonitor to keep track of temps, among other vital pieces of system info. I should probably just go ahead and set it to boot with Windows at this point--it's always running on my second monitor. I also use SpeedFan, also freeware, to set curves and control fans. It's also always running on my second monitor. Between the two programs, I'm just conditioned at this point to, if my fans ramp up unexpectedly, look over at SpeedFan and HWMonitor to see what's up.
Between those two programs, you'll be able to tell if anything is too hot. Just listening to your system fans helps as well. If they're ramping up for no reason, you might want to check your temps.
https://linustechtips.com/topic/604599-fans/#findComment-7837884
It defiantly needs more cooling, I've attached some images of what I would recommend...
Just kidding, it's probably fine.
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
https://linustechtips.com/topic/604599-fans/#findComment-7838370
16 hours ago, DaGallane said:
Planning on using the GTX 1070, just hasn't been released yet.
Then I guess you willl need 2-3 fans.
  • Games owned: 76
https://linustechtips.com/topic/604599-fans/#findComment-7839357
