Yesterday I installed my cable mod extension cables behind my corsair 650m psu cables.
The looks are great but when I was installing them I also Routed a few cables different.
For this i needed to disconnect the hdd and ssd. The optical drive is something I completely disconnected since i dont need it.
After completing it I was happy with the looks but as soon as I booted my pc the motherboard gave out a lot of errors in QCode.
Aswell as leds on the motherboard for cpu, vga and boot_device errors. So I thought I killed it.
I didnt. After a long time on AE with the boot_device led on it went to A0 and i booted into windows 7 without any trouble. I ran a few games and it all worked.
Yet again i noticed that my fans were still going on full rpm after the boot. Normally they slow down.
Knowing this is not right I disconnected the 24 pin and 8pin cpu extension. So now my GPU is the only thing with the extensions.
Still it boots with the same error.
Here are the Q Codes:
00 = Not used
08 = System Agent Initialization after micro code loadin
10 = PEI Core is started
29 = OEM pre-memory initialization codes
25 = OEM pre-memory initialization codes
26 = OEM pre-memory initialization codes
88 = OEM DXE initialization codes
41 = OEM post memory initialization codes
19 = Pre-memory PCH initialization is started
15 = Pre-memory System Agent initialization is started
21 = OEM pre-memory initialization codes
55 = Memory not installed
36 = CPU Post-memory initialization
32 = CPU Post-memory initialization
4F = DXE IPL is started
60 = DXE Core is started
61 = NVRAM initialization
78 = ACPI Module initialization
83 = OEM DXE initialization codes
6A = System Agent DXE SMM Initialization is started
91 = Driver connecting is started
96 = PCI Bus Assign Resources
62 = Installation of the PCH Runtime services
AE = Legacy Boot event
AO = A0 - IDE initialization is started
My windows is on my ssd and my steam is on my hdd. So i know they did not fail because of the fact it still ran games.
My specs:
My motherboard is an Vii formula
Cpu: i7-4790k
Gtx 970 gpu
1 ssd and 1 hdd
Corsair 650m psu
In a phanteks enthoo pro case with the case fans on the fan hub inside
I dont have any clue what is wrong, please help
https://linustechtips.com/topic/603973-motherboard-errors-for-days/
