Codecademy help
Go to solution Solved by GreezyJeezy,
4 minutes ago, unknownindividual said:
Its the same thing
Still doesnt work
after the rare 10/10 you need to put a ; so like this
var feedback = prompt("rate your game 10 out of 10");
 thats how it should be
1 minute ago, Gachr said:
Wait... Does codecademy really teach JS without semicolons? It's worse than I thought...
no it doesn't. It's actually not that bad though it does mess up a little. like at one part it will teach you to do functions like this.
var function1 = function(){
//stuff
then change to
function function1(){
//stuff
but it doesn't actually tell you what the difference between them is or how they could be used.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/603799-codecademy-help/#findComment-7827163
//stuff
then change to
//stuff
Well, the lack of semicolons can mess up a lot. Also, that function thing is really weird, if one of them is the "right" way, then it's the one they started with but then stopped using.
https://linustechtips.com/topic/603799-codecademy-help/#findComment-7827239
neither are the right way they are just different.
I first is parsed when it gets to that line where as the second is parsed at the start.
For example
if(check)
  function doodoo()
    //stuff
}else
The function would be available regardless of the check.
https://linustechtips.com/topic/603799-codecademy-help/#findComment-7827413
