I've been messing around with overclocking my GTX 760 some more and I've found a stable overclock but the temperature is the thing I'm somewhat worried about. Is a 90C temp safe to be running on a reference GTX 760? Is 90C really safe for any GPU or do I need to lower the power/temp limit for my card?
Gaming Desktop - AMD Ryzen 7 5800X, MSI MPG B550 Gaming Plus, 32GB Cosair Vengenace LP 3600mhz, EVGA RTX 3070 XC3 Ultra,  Sabrent Rocket 4 1TB NVME SSD, Crucial P3 4TB NVME SSD, 4TB Mass storage, EVGA 750W G2, NZXT H9 Flow
https://linustechtips.com/topic/602786-safe-graphics-card-temps/
90c is pretty high. Keep it below ~85c if possible.
https://linustechtips.com/topic/602786-safe-graphics-card-temps/#findComment-7816119
90C aint a good idea. Ramp up the fan speed and try to knock this down to sub 85. Otherwise, reduce the voltages.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/602786-safe-graphics-card-temps/#findComment-7816121
4 hours ago, EmpiracyRyNiX said:
I recommend taking down the overclock a tad bit and ramping up the fan speed about 15-20%. Use MSI Afterburner to do this in real time so you dont have to turn off your pc all the time while overclocking.
I was actually able to just lower voltage and power limit and still maintain the overclock i had and keep it stable. I was actually able to push it even further and get a higher clock with temps staying at 81C
https://linustechtips.com/topic/602786-safe-graphics-card-temps/#findComment-7817519
that sounds great :)
81°C is fine for your GPU.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/602786-safe-graphics-card-temps/#findComment-7817870
Well the R9 290 ran at 95C out of the box so I'd say 90 is okay especially for an older GPU like yours. Sure it will reduce the lifespan somewhat but if you plan on upgrading in less than a year don't worry about it.
\\ QUIET AUDIO WORKSTATION //
5960X 3.7GHz @ 0.983V / ASUS X99-A USB3.1
32 GB G.Skill Ripjaws 4 & 2667MHz @ 1.2V
AMD R9 Fury X
256GB SM961 + 1TB Samsung 850 Evo
Cooler Master Silencio 652S (soon Calyos NSG S0 ^^)
Noctua NH-D15 / 3x NF-S12A
Seasonic PRIME Titanium 750W
Logitech G810 Orion Spectrum / Logitech G900
2x Samsung S24E650BW 16:10  / Adam A7X / Fractal Axe Fx 2 Mark I
Windows 7 Ultimate
4K GAMING/EMULATION RIG
Xeon X5670 4.2Ghz (200BCLK) @ ~1.38V / Asus P6X58D Premium
12GB Corsair Vengeance 1600Mhz
Gainward GTX 1080 Golden Sample
Intel 535 Series 240 GB + San Disk SSD Plus 512GB
Corsair Crystal 570X
Noctua NH-S12
Be Quiet Dark Rock 11 650W
Logitech K830
Xbox One Wireless Controller
Logitech Z623 Speakers/Subwoofer
Windows 10 Pro
https://linustechtips.com/topic/602786-safe-graphics-card-temps/#findComment-7817917
95*C is for Hawaii, not Kepler.
I'd keep it under 80*C if possible
https://linustechtips.com/topic/602786-safe-graphics-card-temps/#findComment-7818033
Yeah but this is only what the company says is ok.
They're both circuits at 28nm. There shouldn't be that much of a difference in heat tolerance since they are just different arcs on the same node.
Doesn't the 760 throttle at that temp though? When does it throttle?
AMD R9 Fury X
Windows 7 Ultimate
Noctua NH-S12
Logitech K830
Windows 10 Pro
https://linustechtips.com/topic/602786-safe-graphics-card-temps/#findComment-7818152
The difference is the way everything is soldered together
https://linustechtips.com/topic/602786-safe-graphics-card-temps/#findComment-7818156
44 minutes ago, don_svetlio said:
Soldered
Ok.
What soldering do you mean? There really isn't a heatspreader on the die. You mean the die itself? The processes from AMD and Nvidia can't be that much different.
Also 97C is fine according to Nvidia:
http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-760/specifications
AMD R9 Fury X
Windows 7 Ultimate
Noctua NH-S12
Logitech K830
Windows 10 Pro
https://linustechtips.com/topic/602786-safe-graphics-card-temps/#findComment-7818203
5 minutes ago, Vode said:
Ok.
97*C is thermal shutdown
90*C is dangerous
85*C is max safe
https://linustechtips.com/topic/602786-safe-graphics-card-temps/#findComment-7818225
