Check that the video card is plugged into the PCI-e completely. If that doesn't change anything, remove it and use the onboard graphics. If the issue is gone you can confirm that it is the GPU. If not, then it could be the monitor or (HDMI?) cable.
i7 6700K, Gigabyte 1080ti, Corsair 16GB, 850 Evo 500GB
Corsair Strafe RGB Brown
https://linustechtips.com/topic/602580-i-need-help-pls/#findComment-7814667
