So... I've got issues where my system will randomly disable win 7's aero theme stuff and the GPU will start jumping from like 80% + usage then back to 0 in like a second of an interval from each other... Anyone else had this kind of issues with the Asus 980 Strix card, and able to fix it? Or is it even the graphics cards problem at at?
When it happens every now and then, sometimes it'll come back to normal in less than a min but in other times i need to reboot my pc to fix this... Any ideas guys?
https://linustechtips.com/topic/602529-possible-asus-980-strix-issues/
install DDU and reinstall fresh drivers?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
36 minutes ago, TaylorSwiftOrNon said:
Well i have a 980 strix since launch and i never had any problems with it, but i also didnt run w7. only w8.1 and w10
Doesn't help you much but ditto to what he said, I've had two for the last year and three months and they've been flawless but I've only ran 8,8.1 and W10 too.
CPU: i7 5820K Motherboard: AsRock x99x Fatality RAM: 32GB Corsair DDR4 3000mhz GPU: EVGA GTX 1080 ti SC2 Case: Corsair 780T Storage: Samsung 950 Pro M.2, Samsung EVO 500gb and various WB Storage PSU: EVGA 1300 G2 Display: TBD
