How important is it to match the same speed as my core clock?
Specs atm:
100.00 x 42
1.900 VCCIN
1.230 VCore/CPU Voltage
STABLE
(Pretty bad chip I know)
But my CPU Ring/Cache is set to Auto (3.9Ghz) and the Voltage is at Auto
If i try to raise the clock and the voltage to match the cores, it will blue screen during a stress test.
How should I approach this problem?
https://linustechtips.com/topic/60237-question-about-cpu-ringcache-help-please/
what do you mean by raising the clock and voltage to match the cores?
if its stable with acceptable temps, its stable.
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
The clock of the ring bus which is different to the core clock speed.
You have the ability to alter it on Haswell.
Referring back to the OP
what's volts did you try for the ring?
<p>Mobo - Asus P9X79 LE ----------- CPU - I7 4930K @ 4.4GHz ------ COOLER - Custom Loop ---------- GPU - R9 290X Crossfire ---------- Ram - 8GB Corsair Vengence Pro @ 1866 --- SSD - Samsung 840 Pro 128GB ------ PSU - Corsair AX 860i ----- Case - Corsair 900D
I tried 1:1 to everything
If Vcore was 1.230, the CPU cache voltage was 1.230
