On 5/26/2016 at 11:09 PM, shooter2749 said:
so i want to use javascript to put in my text (about one entire page) and make it appear the same way as if you hold a letter in word (do you understand?)
A) Have no clue what you mean.
B) This should be put in the programming topic, not off topic. Ask one of the mods to move it for you.
EDIT: I also realized how old this post is now. *facepalm*
My system specs: Intel Core i5 8600K (5ghz Overclocked) CPU - ASUS Strix Z370-I Motherboard - Zotac GeForce GTX 1060 6GB AMP! Edition GPU
Corsair H55 Water Cooler - 16GB DDR4 Corsair Vengeance RAM
"People who are crazy enough to think they can change the world are the ones who do" - Steve Jobs, 1955-2011.
https://linustechtips.com/topic/601740-help-coding/#findComment-7815555
