Hi, I am no expert in computers so i hope you can help me.
I attached images of the parts.
They are in spanish but there are the pictures and the name so there should be no problem (Google transleator if needed xD  )
I only wish to know if everithing will fit and if the power supply will be able to handel it if i put more watts would it harme it? ( to put another grafics card later on) (wolud it fit in the case?)(I attache power supply calculator Image)
Could i put the cooler of the grafics card in the fron place (instead of a fan)?
Is that motherboard good and compatible with all the other parts ?
And any other advice you could give me, thank you very much
I know is a lot to ask but i would apreciate it a lot ;)
https://linustechtips.com/topic/601736-help-with-first-build/
no
yes
yes
Fury X performance is good but not the best and with the new cards from Nvidia being released with much better performance, picking one of those up would be recommended.
Also you need to get a powersupply of better quality, wattage is fine however. See if you can find a Corsair RM650x or EVGA Supernova 650w G2/GS or GQ. Or any Seasonic/Superflower/XFX powersupply.
Also i would recommend you get an Intel i5 processor as they give better performance (will need to change motherboard). An i5 4460/i5 6500/i5 4690k or i5 6600k (ranked in which performs the best from slowest to fastest, overclock included) would be my picks.
https://linustechtips.com/topic/601736-help-with-first-build/#findComment-7805198
