SURFACE PRO 3 WIFI ISSUES HELP
By
Miu_Amaha
in Troubleshooting
in Troubleshooting
Solved by Mug,
- Turn off and on again
- Use Windows diagnosis tool
- Re-install Drivers (they're on the support website)
- Diagnose the fault - Is it the antennae or what? (You can tell if it's the antennae for example because Bluetooth won't work)
- Call up Microsoft for a repair service
3
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases5 -
2
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning18
play_circle_filled
Latest From ShortCircuit:
