Hello! I have a problem with my gen 1 G15.
Everynow and then the numlock freezes and my tab button stops working. First I thought it was my windows installation that was the problem so I re-installed it. Nope, problem persists. Then I thought it was play in the cable. Nope. It starts working now and again, and then it stops.
Tried google to no avail so I've decided to try my luck here!
https://linustechtips.com/topic/60096-keyboard-problems/
Clean your keyboard.
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/60096-keyboard-problems/#findComment-816085
UPDATE: My esc button wont work either.
Did that, doesn't work. It's like those keys freeze at a certain point and when one freezes, all them stops working.
As in...under the keys.
https://linustechtips.com/topic/60096-keyboard-problems/#findComment-816105
As in under the keys. On the other hand. If there is dirt under the Numlock, why would only the tab and esc-button stop responding and not any other?
Because dirt under-neigh the membrane could cause a signal to get cut off.
Take the keyboard apart totally and clean it thoroughly.
If that doesn't fix it, either there is something on your computer or the keyboard has reached the end of its life.
https://linustechtips.com/topic/60096-keyboard-problems/#findComment-816132
This kind of sounds more like a simple case of a worn out keyboard to me. I would look under the keys to see if there's anything you might be able to clean off though. Have you tried a separate bank of USBs, such as your front ones instead of your back ones?
Corsair 900D | MSI MPower Max Z87 AC | i7-4790K @ 4.7Ghz | 1080 Ti SLI | 16GB Corsair Vengeance Pro 2400
XSPC Raystorm | EK-FC Nickel GPU block/backplate | 2x Alphacool UT60 480mm & XT45 240mm | 11x Linus Edition NF-F12
Schiit Modi/Magni 2 Uber | 5" KRK Rokit G3 | KRK 10S2 | Acer Predator X34 | Dell S2716DG
https://linustechtips.com/topic/60096-keyboard-problems/#findComment-816148
Don't take it apart, especially if it's membrane. Chances are you'll just ruin it.
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/60096-keyboard-problems/#findComment-816195
You can only ruin it, if you force it apart and mishandle it.
https://linustechtips.com/topic/60096-keyboard-problems/#findComment-816213
Well if it is as DaftBehemoth says, and it is just and old keyboard and about to die. I'm willing to go all in.
:P
Just open it with a screw driver, take the main parts apart and clean with q-tips or something.
Put it back together, see if its still not working, if it isn't its time to find a new keyboard xD
https://linustechtips.com/topic/60096-keyboard-problems/#findComment-816276
Well there is some keyboards where the domes are all separate. Putting one of those back together is a pain, but I would not expect the G15 to have separate domes, and instead have a sheet which they are all on.
https://linustechtips.com/topic/60096-keyboard-problems/#findComment-816279
Yeah it is kind of a pain to put together heh...
https://linustechtips.com/topic/60096-keyboard-problems/#findComment-816344
Well, if you're me, then don't.
I somehow managed to destroy one of those super-thin cables coming from contacts to the PCB. (it was a G11)
https://linustechtips.com/topic/60096-keyboard-problems/#findComment-816460
Reason why certain keys that are close to each other will stop working at once is that its membrane keyboard. In membrane kb's keys are arranged in clusters which have something like 4-9 keys in one cluster. If that cluster stops working, then nothing you can do about it. My X6 went RMA two times because cluster at jkl stopped working. Same problem like you, no responce and when they did it was many letter at once. Get new kb.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/60096-keyboard-problems/#findComment-818457
