Cable-less USB hub
By
j29
in Peripherals
in Peripherals
Solved by DaftBehemoth,
If you don't have a separate power adapter, you're going to run into power issues since all the USB ports are going to try to run off of the power of a single USB connector. I'd say the hassle outweighs the gains ![]()
thedood2k ·
Posted in Power Supplies2 -
DARTHDIVIDER0213 ·
Posted in Troubleshooting8 -
1
Xx-albinos-xX ·
Posted in Troubleshooting10 -
2
_Darasuum_ ·
Posted in Power Supplies6 -
1
4
play_circle_filled
Latest From ShortCircuit:
