hey guys, I currently own a FSP Aurum CM Gold 750w modular power supply and after i had my system water cooled  i discovered that the power supplies fan is really loud when the system is under load. (really loud relative to the silence of the water cooled loop)
I was wondering if i could switch the default fan out from the psu and switch it to a better fan, lets say a noctua nf-f12 to make it more silent?
what do you guys think?
Good, Bad, lemme know!
thanks in advance :)
https://linustechtips.com/topic/60045-loud-power-supply/
you can replace the psu fan with any 3 pin fan. its fairly simply to do but you void your warranty the moment you open the psu, so take your risk.
PC Builder, Engineer... BACON    Project Cobalt: http://linustechtips.com/main/topic/38058-project-cobalt-copper-piping-laser-etching-and-more/#entry489258
| NZXT Switch 810 | i5-3570k | gigabyte UD-5H | Corsair Vengeance 8gb ram | GTX 670 | 2x 60gb intel 330 series ssd's in raid 0 | 1tb seagate barracuda hdd | Corsair tx750m | XSPC razor GPU and CPU waterblocks | XSPC d5 vario pump | Thermochill Pa140.3 | phoyba 280mm radiator | Chromed Copper tubing |
https://linustechtips.com/topic/60045-loud-power-supply/#findComment-815244
And if you open it, DONT TOUCH ANYTHING
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
https://linustechtips.com/topic/60045-loud-power-supply/#findComment-815288
I guess you tried that?
Cpu: Intel core i5 4570 gpu: gtx 770 case: cm storm enforcer psu: xfx pro 550w motherboard: asus b85m-g ssd: samsung 120gb hdd: wd caviar blue 1tb ram: kingston hyperx blu 8gb 1600mhz mouse: razer deathadder monitor: some decent samsung 19" keyboard: CM Storm TK Blue
https://linustechtips.com/topic/60045-loud-power-supply/#findComment-815320
no, almost did though.
https://linustechtips.com/topic/60045-loud-power-supply/#findComment-815329
how long have you had the PSU? IMO, it is never a good idea to mess with the guts of something like a PSU. Just use the warranty service.
I get 60 frames at 1080p on a dual core APU. Ask me how.
AMD FX 8350 CPU / R9 280X GPU / Asus M5A97 LE R 2.0 motherboard / 8GB Kingston HyperX Blue 1600 RAM / 128G OCZ Vertex 4 SSD / 256G Crucial SSD / 2T WD Black HDD / 1T Seagate Barracude HDD / Antec Earthwatts 650W PSU / Coolermaster HAF 922 Case
https://linustechtips.com/topic/60045-loud-power-supply/#findComment-815693
DON'T OPEN IT! (Trust me, take this from someone who did a Cybernetics Degree, worked with power supplies a lot and still wouldn't dare open it).
Seriously, it was only a few weeks ago I read about a boy who was trying to canabalise his PSU for the fan, electrocuted himself, tragically died and was found by his Dad later that evening. Even if it meant buying a new one, because you can't do anything like clean it out any other way then do that. Your life is worth more than the hundred or so £/$ you might save.
Intel 3770K @ 4.4GHz (Summer) - 4.6GHz (Winter) / Asus P8Z77-V Deluxe / EVGA GTX 680 /w Arctic Twin Turbo II / 16GB Corsair Vengeance @ 1866MHz / Samsung 840 Pro 128GB (Steam) / OCZ Vertex 4 128GB (Boot/Office/Steam) / Seagate Barracuda 2TB x2 (RAID 1, Storage) / Asus Xonar D2X / OCZ 1250W ZX / H80i /w 2 x Gentle Typhoons / Cooler Master HAF X /w Pioneer Blu Ray, Aerocool V12XT, 4 x Cooler Master MegaFlows (Red) / Logitech Z906, G930, G19 & G700
https://linustechtips.com/topic/60045-loud-power-supply/#findComment-815797
I would suggest just upgrading to a better quality power supply, something with an 80Plus Gold or Silver minimum rating.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/60045-loud-power-supply/#findComment-832286
The fsp aurum is rated at 80 plus gold, I'm assuming it has a bad fan curve accompanied with a low quality fan is what causes the loudness.
I'm probably going to be looking into the corsair rm series power supplies for a silent replacement
https://linustechtips.com/topic/60045-loud-power-supply/#findComment-834071
