So I'm writing my final for Visual Basic and I've come across some code which if triggered I need to leave the "If" it is in and start the sub back at the beginning. How would one go about this? I dont want to close out of the sub with exit sub but just go back to the beginning of it without resetting it or anything.
https://linustechtips.com/topic/599947-visual-basic-help/
Can you show the code or give any more detail to what you're trying to accomplish?
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/599947-visual-basic-help/#findComment-7786031
