Good LED cable for PC
Go to solution Solved by RNGesusHatesMe,
the widebeam magnetic one from cable mod (i think) are reviewed well
10 minutes ago, RNGesusHatesMe said:
https://www.pccasegear.com/products/34417/cablemod-widebeam-magnetic-led-strip-rgb-kit-30cm these are ones (u can get non rgb (other colours) and longer ones
The only thing is that if I would have Cablemod ship to Sweden the price would be almost as much as the NZXT Hue+, which I btw would take over the Cablemod leds... :/
https://linustechtips.com/topic/599727-good-led-cable-for-pc/#findComment-7783500
On 2016-05-22 at 6:34 PM, RNGesusHatesMe said:
shame that its literally 100 bucs where i am (compared to the 42 of the rgb cable mod one (id go for red led which is 30)  also the hue needs a place to be put (for mini itx form factor like mine this is a issue)
Yeah I'll just wait a bit and see if it comes any good prices. Otherwise I'll supposedly go with something cheap as a normal NZXT led.
https://linustechtips.com/topic/599727-good-led-cable-for-pc/#findComment-7791428
