System
  • CPUintel I7 4790K overclocked at 4.4GHz
  • MotherboardAsus z97 Deluxe usb 3.1
  • RAMkingston Hyper-X 32GB 1866MHz CL10
  • GPUAsus ROG GTX980 matrix platinum, & gigabyte g1 gaming gtx980 windforce
  • Casecorsair 760T Full tower
  • PSUCorsair HX1200i platinum
  • Coolingcorsair H110i GT
Hi guys I have a problem my current system looks like a rats nest and I want to water cool my entire system (GPU and CPU) so that it looks proper is it possible?, what parts do i need and how much will it cost Please I need help this computer cost a lot of money i have seen people like linus (linustechtips), jay (jayztwocents), and paul (paul's hardware) do such beautiful builds.
my current system rats nest:
what i want it look like:
Motherboard: Asus Z97-Deluxe, Processor: Intel i7-4790K@4.3GHz@1.150Volts, GPU: Asus ROG GTX980 Matrix (with a NZXT G10 bracket and a nzxt x41 AIO liquid cooler), Ram: Kingston HyperX 32GB 1866MHz CL10, PSU: Corsair Hx1200i, Storage: 1TB Seagate SSHD with a Kingston HyperX Fury 240GB SSD, Display: BenQ XL2411Z, Keyboard: Corsair K70 RGB, Mouse: Razer Deathadder chroma.
pc part picker list:
https://pcpartpicker.com/user/hu0210/saved/#view=qHK6XL
https://linustechtips.com/topic/599700-help-water-cooling-non-reference-gpus/
8 minutes ago, Edwardk326 said:
System
search for alphacool nexxus or something gpu blocks
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
6 minutes ago, Nacho Marco Segui said:
Can you be less helpful?
http://www.alphacool.com/shop/gpu-cooler/?p=1&o=1&n=12&f=94
Build
9 hours ago, DeezNoNos said:
my idea is this since ek and alphacool don't make a specific full waterblock for the rog matrix gtx980 platinum i will use a universal waterblock from ek (https://www.ekwb.com/shop/ek-vga-supremacy-acetal-nickel), or this one (https://www.ekwb.com/shop/ek-thermosphere-acetal-nickel, https://www.ekwb.com/shop/ek-thermosphere-mounting-plate-g200) to cool the gpu anyway this guy has the basic idea of what i want to do
the only issue that remains is how to cool the vrms (voltage regulator modules) since i hear the become very hot under load
anyway let me know
anyway let me know
With passive heat sinks, there to find some good ones
Build
2 hours ago, Edwardk326 said:
-SNIP-
For the gigabyte GPU EKWB should have a full cover waterblock for that but the fact that you have two different GPU's is going to cause an issue with SLI setup for cooling as it can't use something like the terminal block from EKWB to cool both blocks. It may be a good idea of get both of the same cards or to possible get a GTX 1080 and a waterblock when they come out for it
Alphacool has universal full cover blocks
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
4
I think maybe I will leave the rog matrix gtx980 platinum for another system build possibly with a 6700k processor. I think there is no way to water cool the rog matrix gtx980 platinum without using an all in one water cooler paired with the nzxt g10 bracket or using a universal water block from ek or alphacool
as for gigabyte I thank the heavens above they make water blocks the gpu I have. I will have to see how it goes
now all I need is a part list I already have a basic idea of what I need....I think :( not sure
-->ek-vga supremacy universal gpu water block (https://www.ekwb.com/shop/ek-vga-supremacy-acetal-nickel)
-->ek kit x240 (https://www.ekwb.com/shop/ek-kit-x240)
-->ek fc980 gtx wf3 (https://www.ekwb.com/shop/ek-fc980-gtx-wf3-acetal-nickel)
-->some tubing and fittings to make it all work together
it would all come around to $550 not bad assuming it is done properly
the next 2 issues I have is tied in with my location since I live in the united arab emirates
1) where do I get the parts from?
and
2) who is knowledgeable enough to do all this work? because the last time the I gave my computer in for assembly. they didn't know how to do cable management, they didn't connect the front panel connectors properly hence the computer would start hence I had to take it all apart and start over again, I can't imagine what will happen to my beloved $2500 pc with water cooling in these guys hands
I need to find someone like these guys to do the water cooling
Paul (pauls hardware)
Dimitri (hardware Canucks)
Linus (linus tech tips)
Jay (Jayz two cents)
ncix
because it's no joke one small leak and I could damage my entire pc, Then what these people over here they aren't exactly known for their helpfulness "I'm sorry no warranty no warranty why not simply buy a new graphics card nobody repair why repair sorry sorry please you wan't buy new one" and that's the end of that?
anyway if you guys know any really good pc builders in the united arab emirates like the guys mentioned above let me know. in the mean while I'm going to try and contact some friends and see if they can help me out. Wish me luck because I am so out of it :(
thanks but I checked it and I don't think it will work for the rog matrix gtx980 platinum because the pcbs look slightly different when compared to one another
pcb of gtx980 strix:
pcb of my gpu rog matrix gtx980 platinum is the same as the gold 20th anniversery edition:
which this girl talks about:
bahahaha.... lol those VRMs... must be like 20 of them
yeah it looks like Alphacool only has the Matrix Platinum only for 780
but doesn't that EKWB fit you from the screenshot?
yeah it does anyway it seems as though i will either have to find way to passively cool the vrms or continue using an aio liquid cooler along the nzxt g10 the problem with an aio liquid cooler is that i hate the way it aesthetically looks anyway thanks for you help guys
