I have been planning this PC for a long time now and with the time tech always evolves. I am still waiting for the 1080 to finally release before I order any parts, and thats where I need you're help.
I always wanted to have the Phanteks Evolv ATX but when I came to realised that the case's maximum E-ATX MOBO support is 266mm I was shot into a spiral as The MSI Godlike that I want to include is 272mm wide. Doing my research I came across this pc build (http://pcpartpicker.com/b/HQm8TW) that had someone put a 272mm motherboard (Asus rampage V extreme) into the Evolv ATX. Should I atempt the same feat or wait for smaller X99 boards?
This brings me to my second question, with Computex right around the corner and speculations of Asus X99 boards should I be waiting for newer boards or trying to cram oversized E-ATX boards into the Evolv ATX?
for any of you that are interested in my PC specs
http://pcpartpicker.com/p/CsGv8d
https://linustechtips.com/topic/599570-what-case-and-mobo/
12 minutes ago, JD28 said:
your mobo fits just fine! i would wait for the 6800k which is rumored to be released on cumputex in a couple days.
PCPartPicker part list: http://pcpartpicker.com/p/BYxhD3
Price breakdown by merchant: http://pcpartpicker.com/p/BYxhD3/by_merchant/
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($369.99 @ SuperBiiz)
CPU Cooler: Noctua NH-U12S 55.0 CFM CPU Cooler  ($61.99 @ Amazon)
Motherboard: Asus X99-A/USB 3.1 ATX LGA2011-3 Motherboard  ($228.99 @ SuperBiiz)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($49.99 @ Newegg)
Storage: A-Data Premier SP550 480GB 2.5" Solid State Drive  ($108.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Amazon)
Case: Phanteks Enthoo EVOLV ATX Mid Tower Case  ($179.99 @ Amazon)
Power Supply: Corsair RMx 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($109.99 @ Amazon)
Other: custom cables (Purchased For $119.90)
Other: GTX 1080 ($699.00)
Total: $2677.82
Generated by PCPartPicker 2016-05-22 04:17 EDT-0400
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
https://linustechtips.com/topic/599570-what-case-and-mobo/#findComment-7781892
8 minutes ago, JD28 said:
yeah its x99 and the same price as the 5820k.
the msi godlike or rampage are normal atx boards they fit in fine. the case even supports bigger e-atx boards that can fit 2 cpu's. its a standard. im pretty sure you confused height and width of the boards.
love that german :D
https://linustechtips.com/topic/599570-what-case-and-mobo/#findComment-7781915
