What's the best $50 PSU.
CPU: Intel Core i7 3770 @ 3.91 GHz RAM: G.Skill 4x4GB 2133Mhz DDR3 GPU: AMD HD 7970 3GB SSD: Samsung 840 Evo 500GB PSU: Corsair HX620W  Motherboard: Gigabyte Z68X-UD3H-B3 Case: Phanteks P400 Tempered Glass (Black) Monitor: Dell P2412H, Dell 2012H Keyboard: Razer BlackWidow Ultimate Classic Mouse: Logitech G203 Prodigy HDD: WD Black 3TB
https://linustechtips.com/topic/599454-best-50-psu/
What are you powering? GTX 970? Get a nicer PSU. No-GPU system? A Corsair CX450M will be fine.
https://linustechtips.com/topic/599454-best-50-psu/#findComment-7780718
Im powering an AMD X4 845 and a 750ti.
https://linustechtips.com/topic/599454-best-50-psu/#findComment-7780724
Surely there's a better alternative to a CX450.
I'm not familiar with all the under 500W PSU's but I doubt a CX PSU was anywhere close to the best option.
There's some SeaSonic units down there I'm sure.
https://linustechtips.com/topic/599454-best-50-psu/#findComment-7780726
The new CX series grey units are far superior to the green ones.
A CX450M would be perfect.
https://linustechtips.com/topic/599454-best-50-psu/#findComment-7780733
The new units are solid.
https://linustechtips.com/topic/599454-best-50-psu/#findComment-7780738
@Starelementpoke @STRMfrmXMN @Hunched @DEcobra11
So what is the best PSU? Also I want a unit with decent cables ( aka no mustard or ketchup cables)
https://linustechtips.com/topic/599454-best-50-psu/#findComment-7780858
The Seasonic S12 or Corsair CX450M would both be good but the Corsair is modular so I would lean towards it.
https://linustechtips.com/topic/599454-best-50-psu/#findComment-7780891
