On 21.05.2016 г. at 10:13 PM, Premium_Tech said:
~snip~
Hey :) Welcome to the community!
Pretty much any external HDD should work well on the console. I could suggest checking WD My Passport and WD Elements Portable as possible solutions as both of them work very well for this purpose. If you want something specifically designed for Xbox consoles you can also check out WD My Passport X which comes preformatted and designed to run your games smoothly and to work great with the console.
If you have any questions, feel free to ask!
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/599306-external-hard-drive/#findComment-7797636
