After a weekend in my junk.. oh, sorry, old parts I found old floppy disk drive and a pile of old floppys. I was curious what I wrote 15 years ago so I went to a local computer store and bought an IDE->SATA piece of silicon. And the problem is: This controller includes power pins but my drive has them on a separate cable. I thing you guys are smart enough to tell me what to cut.
Hardware:
-SFD-321B FDD
-SPIF223A-HL022 - based chinese thingy
I don't think you need photos because they are easy to find.
https://linustechtips.com/topic/598743-floppy-disk-problem/
Hardware:
-SFD-321B FDD
Floppy drives don't use IDE And I'm guessing the adaptor is from ide mobo to a sata drive...sounds like you've got the wrong part to get it to work. why not pick up a usb floppy drive from somewhere online?
I am a paid professional, but only when I am at work...and getting paid.
https://linustechtips.com/topic/598743-floppy-disk-problem/#findComment-7773540
Hardware:
-SFD-321B FDD
Cut the red wire?
Waii waiia no.
Dont do that.
xD.
I have no clue. I think you'll have trouble finding an anwser to that. Sorry I cant help.
Hi.
https://linustechtips.com/topic/598743-floppy-disk-problem/#findComment-7773546
13 minutes ago, ddddanil said:
Why I have to buy a new drive if I have a good old one? I think i can just cut power pins on the controller ant it'll be fine. Posting photos now.
Yeah those are completely different interfaces... also the usb floppy drives are pretty cheap I picked up a new one last year for under $10usd. I have loads of "good" 2.5 floppy drives lying around but they're basically worthless to me.
https://linustechtips.com/topic/598743-floppy-disk-problem/#findComment-7773690
1 minute ago, ddddanil said:
If it's only solution... well ok. I wish I'll find one without shipping.
I don't even know if getting a floppy controller to adapt from sata is possible...you could look for a floppy pci add in card of some sort if you've got an empty slot to put it in.
https://linustechtips.com/topic/598743-floppy-disk-problem/#findComment-7773869
