CPU not cooling down after Load
Go to solution Solved by Mira Yurizaki,
2 minutes ago, Rodniz said:
The day, i overclocked the fx, somebody told me to turn cool and quiet off. So i turn it back onn?
Yes. That's what makes it clock down when it's not doing anything intensive.
And there's no need to turn off any power saving features as long as the setting isn't set for aggressive power saving. Hardware and software is smart enough to give you the performance when you need it and there's no point in forcing the parts to run at full speed all the time.
Ive got a question in my mind since a while now and i finally got myself to ask u guys.
I own a FX 6300, which is running at a steady 25-30 degrees after boot up, as long as i just browse and not doing intense stuff.
But as soon as i play a game, have it running under load for some time and relieve him from his load, he doesnt get much cooler anymore.
Hes running on ~70 while load. (I know, it is hot, i dont care, will get a new MB+CPU soon anyways.) As soon as i stop gaming, he gets down to max. 50 degrees, but not any cooler.
The CPU fan doesnt even slow down aswell, pretty loud all the time. I dont care about the Load-Noice since im having Headphones on at that time, but as soon as i stop playing, i want that **** to be quiet
Is there anything i can do about this?
tl;dr
After load, my cpu wont cool down and fan keeps spinning at something littler lower then load rpm.
Budget Rig "Curable":     | FX 6300 @4.5Ghz | Asus R9 270x | Asus Crosshair IV Extreme | 16GB HyperX Beast | 120GB PNY SSD
Tablet "Buddy":                 Trekstor Wintron 10.1|
https://linustechtips.com/topic/598102-cpu-not-cooling-down-after-load/
I'd check the thermal compound in between the CPU and the heatsink. Make sure you have some more to apply before you remove the cooler though.
You may want to look at a aftermarket cooler such as Hyper 212 evo presuming you are using a stock cooler.
Magical Pineapples
2 minutes ago, snortings said:
please quote on the rules where it says I can't post what I did.
On 1/20/2016 at 10:52 AM, Windspeed36 said:
Generally speaking, as long as the following rules are met you should never find yourself subject to disciplinary action:
  • Ensure a friendly atmosphere to our visitors and forum members.
  • Encourage the freedom of expression and exchange of information in a mature and responsible manner.
  • "Don't be a dick" - Wil Wheaton.
  • "Be excellent to each other" - Bill and Ted.
  • Remember your audience; both present and future
Don't be a dick :)  :D
Magical Pineapples
OP: Can you check the clock speeds? Maybe it's not clocking down like it's supposed to. If it's Windows 8 or Windows 10, you can check via the Task Manager. Otherwise you can use CPU-Z or HWMonitor
If you are using the stock cooler, getting a CM 212 would be a good investment too.
1 hour ago, snortings said:
-snip-
The fact is intel stock cooler have this problem too, but the nosie is a bit less noticeable, going to replacing a whole entire platform is gonna to cost around 300 dollars~ . The problem is clearly either his fan profile is fucked and stock cooler and this could be fix through getting a cheap ~30 dollars aftermarket coolers such as hyper 212 evo.
Magical Pineapples
Do you have sufficient exhaust fans for your system. The fact that it sits at 50C after a game suggests there is little airflow. It could also be, like others have mentioned, the thermal paste.
I also noticed you've overclocked your FX 6300 on a stock cooler so it's not really surprising to see those temps. I would suggest investing in a hyper 212 evo at the very least as temps above 65C are not ideal.
CPU - Ryzen Threadripper 2950X | Motherboard - X399 GAMING PRO CARBON AC | RAM - G.Skill Trident Z RGB 4x8GB DDR4-3200 14-13-13-21 | GPU - Aorus GTX 1080 Ti Waterforce WB Xtreme Edition | Case - Inwin 909 (Silver) | Storage - Samsung 950 Pro 500GB, Samsung 970 Evo 500GB, Samsung 840 Evo 500GB, HGST DeskStar 6TB, WD Black 2TB | PSU - Corsair AX1600i | Display - DELL ULTRASHARP U3415W |
I aint got the stock cooler. I got something very similar to the hyper 212, a GELID SOLUTIONS TRANQUILLO 3. I will order some new thermal paste today, to replace that. Ill keep u guys updated.
Allright, ill try that out as soon as im at home
I know you said you know it's hot but you're 10C above the max temp for FX chips (61C for CPU, 71C for socket) which means your socket is probably 80+C, be careful or it will burn out. Consider a nice aftermarket cooler that will be compatible with your upgrade (most are) and just move it to the new system once you get it.
I also have noticed FX chips are overvolted so you can probably drop the voltage quite a bit and still have stability. My FX had a stock 3.1 Ghz (@ 1.26V) that boosted up to 4.0 (@ 1.41V) but I had no problem getting it stable at a constant 4.0 (@1.29V, APM off so no throttling) and it ran a lot cooler than stock (by over 10C) and got way higher benchmarks. 460 vs 550 in cinebench (still pretty bad compared to Intel, haha, but it will hold me over until broadwell-e releases). I had to OC to 4.4 Ghz before I was actually needing the voltage they would boost to.
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
I would keep all those settings on, the only setting that actually slows your CPU under load is APM but be very careful with turning this off, make sure you have a lot of thermal headroom since just turning that off can add 10-20C to you max temp as it will no longer drop clocks/voltages automatically if your CPU is getting too hot. You may as well leave it on since turning it off only gave me about a 5% increase in benchmark scores. (APM can be weird, it was throttling my CPU even when temps were low, that's why I turned it off)
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
I wouldnt even care if the System stops working today. As long as it runs, the way it does, im fine with it. If not, ill buy the new one. I got a nice aftermarket cooler, otherwise i wouldnt be able to Overclock it the way it is.
Topic: It now works, with cool&quiet turned back on. Thank you guys.
