Being confused by a PC game called A.V.A., it claims to provide 200+ fps but if thats true, 200 frames provided in just a second?! That's not even realistic, i mean, 60 fps is already very smooth in a video. Does that 200+fps really means frame per second or other meanings? Thanks all.
https://linustechtips.com/topic/598069-problems-about-fps/
The engine might be able to provide up to 200FPS(meaning it's able to generate that many frames if required), but understand that many games can run at high frame rates. As an example, some people can run games at 144FPS at 1080p, and if the game is easy enough to run, you can hit 300FPS. Is there any value to it? It depends on many factors, including of course, the actual refresh rate of your monitor. If your monitor refreshes at 60Hz, rendering anything above that is pointless, no matter what people want to claim. If your monitor runs at 144Hz, running a game at 144FPS will provide you with the ability to react sooner, and have a smoother gaming experience overall.
https://linustechtips.com/topic/598069-problems-about-fps/#findComment-7766143
200FPS is very realistic to achieve in a game. Most hardware will run CS:GO above those frame rates.
However, having a monitor to display those frames is something different. If you have a 60Hz monitor (refreshes 60 times a second), then you're only going to see a maximum of 60FPS, no matter how many frames your GPU is drawing in the game. If you had a 120Hz monitor (120 refreshes a second) then you could see a maximum of 120FPS, but still not 200, as the monitor can not refresh that fast.
https://linustechtips.com/topic/598069-problems-about-fps/#findComment-7766144
It's impossible for the game to provide the fps, that's based on your computer's horsepower. Unless all of the rendering and calculations are offloaded to a server which you dont own, which I seriously doubt.
Current Build: Core i7 4790k @ 4.6, Asus Maximus VII Hero, Corsair Vengeance Pro 2400mhz 8gb (2x4gb), GTX 980ti, NZXT Kraken X61, Fractal Define R5  EVGA Supernova B2 850w, Some 300gb hard drive.
http://pcpartpicker.com/p/W7CNrH
https://linustechtips.com/topic/598069-problems-about-fps/#findComment-7766145
You now just introduced another factor if that were the case.....the user's Internet connection.
https://linustechtips.com/topic/598069-problems-about-fps/#findComment-7766151
However, having a monitor to display those frames is something different. If you have a 60Hz monitor (refreshes 60 times a second), then you're only going to see 60FPS, no matter how many frames your GPU is drawing in the game. If you had a 120Hz monitor (120 refreshes a second) then you could see 120FPS, but still not 200, as the monitor can not refresh that fast.
They have some Eizo monitors that go up to 240hz now. I think they're like $700 though.
https://linustechtips.com/topic/598069-problems-about-fps/#findComment-7766153
Very true. I think the average civilians internet speed is around 15mbps which is probably not enough to carry that much data that he would be offloading. Unless he was just connecting to the server and playing it from his account on there?
https://linustechtips.com/topic/598069-problems-about-fps/#findComment-7766162
It depends how its worded and intended. True, the game doesn't draw the frames itself, but it could be referring to the fact that it isn't limited to a certain frame rate like some games are.
It's likely we'll see some crazy high refresh rate monitors once new GPUs come out with DP1.3 and up. We're going to hit a point where increasing the refresh rate isn't worth while anymore, though. We may hit that point at 240Hz TBH.
https://linustechtips.com/topic/598069-problems-about-fps/#findComment-7766165
How would you deliver the frames? Even with something like lossless compression, I think it would be a lot of data.
https://linustechtips.com/topic/598069-problems-about-fps/#findComment-7766166
I've already seen some 480hz monitors. At the point of the refresh rate going faster than 300hz it is impossible for your eye to see. They tested some fighter pilots with really trained eyes and flashed an image on a screen for 1/300th of a second. At pretty much any point past 300 it was impossible for even fighter pilots to see. Just thought that this test was really interesting and wanted to share.
https://linustechtips.com/topic/598069-problems-about-fps/#findComment-7766176
At the point of 60fps I think we're already talking A LOT of data. Unless he has a 1-10gbps ISP i think this would be generally impossible.
https://linustechtips.com/topic/598069-problems-about-fps/#findComment-7766192
Flashing an image for a short period of time isn't the same as displaying more images in a second, though. While you may not be able to perceive a single frame, having frames displayed faster could still seem smoother, due to how our eyes don't see in frames, but as a constant stream of information, taken in segments.
We'll have to wait and see (haha, so punny). I'd agree that 300FPS is probably too much to make any noticeable difference above something like 240Hz, but we won't really know until they become more widely available and tested.
https://linustechtips.com/topic/598069-problems-about-fps/#findComment-7766213
