I have steelseries siberia v2 headsets. they feel good at first but after an hour they start to hurt (i have glasses and cant see without them)
I have a Blue Snowball Mic so I just need something for sound
This is solely for skype though. When im not using skype i use speakers. I need earbuds for skype. As long as they don't sound like shit i will be happy. about a 50 dollar budget. cheaper the better :D
Fractal Design Define R4 | MSI x79a-GD45 | 3960X @ 4.6Ghz | Lots of EK Blocks | EVGA GTX780Ti 3GB | Corsair Dominator Platinum 16GB (4x4) DDR3 1866 | Samsung 840 Pro 512GB SSD | Western Digital Red 2TB x4 (Raid 10) | Corsair AX760 | Windows 7 Professional 64-bit
https://linustechtips.com/topic/5977-earbuds-for-sound/
I've had good experiences with meelec. You should find something from them to fit what you need.
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
https://linustechtips.com/topic/5977-earbuds-for-sound/#findComment-66482
Meelec have always been good value, as with Brainwavz and Dunu. I would also look at the Astrotec AM-90 http://www.amazon.com/Astrotec-Balanced-Armature-Moving-Headphones/dp/B008FLWPKO/ref=sr_1_113?s=aht&ie=UTF8&qid=1362300122&sr=1-113&keywords=headphones, these seem to be getting great reviews on Head-fi.
https://linustechtips.com/topic/5977-earbuds-for-sound/#findComment-66537
