Reduce background noise on blue yeti?
Solved by ShadowCaptain,
1 minute ago, r1Ns3 said:So there isn't a way just to make it so the mic goes "Oh, this noise was lower than 25%, I will completely ignore it in the recording"?
microphones do not work that way, and even if you set a "minimum" level, as soon as you start talking the background will come back in
you can use audacity to "analyse" a section of background sound and it can be deleted from a recording, but not during live use
The mic doenst have a low pass filter, and even if you added one via software, it could also cut off some of the bass in your voice etc
